My first FAIL please help! Electrical diagnosis
Old Mar 2, 2010 | 10:40 AM
Zector's Avatar
Question My first FAIL please help! Electrical diagnosis
What's up guys thought I'd ask the local scion owners before I took it to the dealer....
Ok so here's what my dumb*** did, I picked up a subwoofer and amp the other day and I was attempting to install yesterday. So when I pulled out the spare and other trunk parts I found my car was already wired for subs, I was like sweet!, all I need to do now is just plug inthe amp and subs. So I went over to the engine bay and found the already installed power wire and I added a fuse and connected it to the battery.... THIS IS WHERE I ____ED UP...I didn't take out the fuse first and also I trusted the already installed wiring. so the fuse blew of course an now my car has been dying at idle...so yeah I can still drive the car but I have to kinda hold the gas down a lil at idle in order to keep the car running... I'm thinking it's a fuse or relay of so e sort but I'm just not exactly sure where to start...so yeah I feel pretty stupid about his whole ordeal...any help at all would be appreciated greatly.
Thanks in advance
Oscar z
Old Mar 2, 2010 | 10:16 PM
asianorange's Avatar
Just a couple weeks ago there was a similar thread due to a possible short
https://www.scionlife.com/forums/sho...d.php?t=181431
Resetting the ECU seemed to temporarily fix the idle but the MAF was toasted.
Hope this helped!
Old Mar 4, 2010 | 08:19 AM
skakemokid's Avatar
You just need to reset your fuel trims i think .. Do you have any mods on the car? ie. intake, header, exhaust?
Old Mar 4, 2010 | 09:22 AM
Zector's Avatar
Hey thanks guys,
so reseting the ecu worked...I talked to the tune up tech at the dealer I work at and he said to clean up the throttle body, let it run for like 5 minutes, then disconnect the battery and let it sit for like 15 minutes to reset the ecu... and after a short drive it was all good!
So I guess what happened was that I spiked the voltage either at the ecu or maf sensor and that threw it off until I reset everything and cleaned the tb ...
Thank u all for your help I really appreciate it
Next time I'll slow down and make sure I don't skip any steps lol
yupinmytC
22
Jul 27, 2024 07:08 PM
mudguy
Oct 22, 2015 04:31 PM
Scionxa180
Scion xA Aero & Exterior
Sep 24, 2015 10:58 PM
carbinefreak
Sep 24, 2015 02:06 AM
Andrew75
Jul 26, 2015 08:13 PM
