2008 Scion tC wiring diagram?
Old Mar 9, 2010 | 11:05 PM
getaforknjob's Avatar
Default 2008 Scion tC wiring diagram?
I'm looking to see if anyone has a wiring diagram for a 2008 scion tC?
I tried to hard wire my AEM FIC, and now I'm throwing seven codes and I would like to know where to rewire a few wires correctly.
If anyone would have any insight without me having to purchase a diagram..
The codes are:
P0010: Cam Shaft Position Actuator Bank 1 Circuit Malfunction
P0113: IAT Sensor 1 Circuit High Input
P0118: Engine Coolant Temp. Circuit High Input
P0123: TPS/Pedal Position Sensor High Input
P0335: Crank Shaft Position Sensor A Circuit Malfunction
P0453: Evap Emission System Pressure Sensor High Input
P2135: TPS/ Pedal Position Sensor/ Switch A/B Voltage Correlation
Old Mar 10, 2010 | 12:55 AM
my06tc's Avatar
not sure if this could help you out
http://www.dezod.com/tech_notes.cfm
Old Mar 10, 2010 | 01:07 AM
SquallLHeart's Avatar
the 2007 wiring diagram in the sticky should be the same for the majority of the parts you need to look at.
Old Mar 10, 2010 | 01:37 AM
Yeah I saw there was an 07 diagram in the stickys, but I didn't know if any wires were different from 07-08.
Would anyone be able to verify this?
Just so the rest of the mods know, I'm posting this in the Forced Induction section also because it does relate to force induction.
Old Mar 10, 2010 | 02:06 AM
Superman05's Avatar
delete me
Old Mar 10, 2010 | 06:18 PM
there are very slight differences, however the only one i can particularly think of is more involved in the audio system and the standard iPod integration resulting in a change in the harness.
the ECU should be the same.
Old Mar 11, 2010 | 01:37 AM
Problem solved for now.
I had to put resistors on the crank and cam shaft wires.
streetracerr
Jul 11, 2015 09:52 PM
wwotr
Mar 28, 2015 01:47 AM
lexobx
Scion xD Drivetrain & Power
Dec 7, 2014 05:52 PM
ggdragonwagon
Dec 3, 2014 04:44 PM
ScionizeD
Dec 4, 2003 10:33 PM
