Jacking question
Old Mar 14, 2010 | 11:55 AM
XBinRochester's Avatar
Default Jacking question
Has anyone been successful in jacking your XB2 with the rear jacking tower? My floor jack just won't lift my XB high enough for the tower to work. If anyone has been successful, what is the jack height required to utilize it?
Old Mar 14, 2010 | 02:05 PM
BozzMan's Avatar
What do you mean by "jacking tower". I just use the jacking points under the rocker panel specified in the owners manual. I do use a solid 2" aluminum block with a groove cut in it sitting on top of my floor jack to cut the distance between my floor jack and the jacking point on the car. My floor jack needs this block when I jack up my wife's Element or it won't lift it high enough to get the wheel and tire off. Hope this helps.
Old Mar 14, 2010 | 08:21 PM
TrevorS's Avatar
Look under the rear of the car a little ahead of the rear wheels. There's a single grey post extending down from the chassis.
Old Mar 14, 2010 | 10:55 PM
strtrcril87's Avatar
The tower works just fine with my 3 ton jack.
Old Mar 14, 2010 | 11:08 PM
Cool, do you know the height your jack is capable of going? I've been looking at buying a new jack and I'm not sure which ones will work.
Old Mar 15, 2010 | 12:59 AM
My guesstimate would be approximately a foot.
Don't get some cheapo little jack, get a beefy 2 or 3 ton jack.
Old Mar 15, 2010 | 09:58 AM
Since the tower is about a foot off the ground (haven't lower her yet), the jack would have to have a lift height of 2 feet to work?
Old Mar 15, 2010 | 10:22 PM
Check this one out: http://www.summitracing.com/parts/SUM-918000
Maximum Lift Height
19 15/16 in.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
jairolla_89
Apr 2, 2015 09:41 PM
Scionxa180
Mar 13, 2015 04:39 AM
xBassist
9
Jan 21, 2004 07:34 PM
