Fuel Injection Pressure Damper??? What is this?
Old Mar 22, 2010 | 10:06 PM
johnhawkins's Avatar
Default Fuel Injection Pressure Damper??? What is this?
I have seen this on my fuel rail since I bought the car. What exactly does this do? Is it necessary to keep on the vehicle?
Old Mar 22, 2010 | 10:47 PM
Ace83's Avatar
Ronin Scion
i thought of that too. but i guess it does what it says especially on a returnless system helps fuel pressure be stable.. not sure what it really does
Old Mar 22, 2010 | 11:26 PM
skinnayyy's Avatar
Team Scionara
probably does the same thing that our "balance shaft" does haha
Old Mar 22, 2010 | 11:41 PM
Do the return fuel systems eliminate this?
Old Mar 23, 2010 | 12:51 AM
crush02342002's Avatar
as far as i know all return systems do away with it simple because most come with their own fuel rail. the FPD (fuel pulsation dampner...I think thats the proper term for it) mounts on the fuel rail so with an aftermarket fuel rail there isnt a place for it to bolt onto.
Old Mar 23, 2010 | 12:52 AM
btw the FPR (fuel pressure regulator) takes the job of this dinky thing (sorta)
Old Mar 23, 2010 | 12:53 AM
So think its better to keep it in on a returnless sytem?
Old Mar 23, 2010 | 01:56 AM
I dont see the harm in having it on a returnless system
Old Mar 23, 2010 | 01:40 PM
Ace83's Avatar
Ronin Scion
I think its more for a returnless.. opening and closing of injectors I think creates pulsation due excess pressure backing to the pump so it kinda dampens it. On return system the excess fuel goes back like a one way traffic. i dont know just the way i see it
Old Mar 23, 2010 | 05:15 PM
Makes sense....I guess Ill keep it in. thanks guys
Old Mar 23, 2010 | 05:56 PM
DezodDon's Avatar
Many fuel systems have this, both return and returnless. It's job is to balance the pressure drop in the fuel rail when the injectors open. When using a stock rail which holds enough fuel to supply 4 stock injectors you want a constant pressure and volume above the injectors. This helps maintain proper metering of fuel at all times. On a fuel system using a larger volume rail, high flow pump and larger regulator it's not as much of a concern as there is generally enough fuel on tap to avoid that problem.
Old Mar 23, 2010 | 07:29 PM
Nice - Thanks Don
brett561tc
Sep 15, 2015 06:33 AM
Garrettthepatwa
Sep 2, 2015 04:40 PM
elwaylite
Aug 9, 2015 09:21 PM
Subaru86
Jul 31, 2015 04:00 AM
boxcar87
Jul 12, 2015 12:16 AM
