Ebay fog light install help!!!
Old Mar 23, 2010 | 05:47 PM
Panatha13's Avatar
Default Ebay fog light install help!!!
OK...ive searched all over this forum and other forums and have no help whatsoever!!! i purchased these fog lights from ebay: http://cgi.ebay.com/ebaymotors/2007-...Q5fAccessories
im trying to install them but im clueless about how these supposedly can plug into the wiring harness that is already in my car???? i saw a post on here with someone who installed them but the pics dont work for me!!! can someone please help a lost soul out!!!??? please???? pretty please????????? if you come to jersey ill buy you a drink!
Old Mar 23, 2010 | 06:28 PM
tlk90's Avatar
I'm from jersey but at RIT at the moment otherwise i'd come help. But If you temporarily take off the plastic under the fog light and around the wheel well.. you can pull it down to see under. The wiring harness is a simple plug and play. They pre wired this for TRD fogs but most of the fogs you buy online are meant to adapt as well.
When you take the plastic lining away you should see the harness just chillen there. Its pretty close to the headlight, harness, sitting a little further down under it if I remember correctly.
Hope this helps...
chrischoi's Avatar
There's a fog light plug already there.
Old Mar 23, 2010 | 06:30 PM
Panatha13's Avatar
ill take a look tonight when i get home and try and figure it out...if not, ill be back on here with pics to post so you guys can help me more
Old Mar 23, 2010 | 06:37 PM
GQQSE13's Avatar
its right inside the front driver's side fender; mine was wrapped up in black electrical tape
Old Mar 23, 2010 | 06:38 PM
aparreira9586's Avatar
these are not the apt/vrd style they are ESUSE style, i had one of those b4 getting apt's and they are NOT pnp at least mine weren't you have to wire the whole thing through your firewall. along with the switch provided.... i dont have any pics...srry
Panatha13's Avatar
what do i do with all the extra wires coming out of the wiring harness for the fog lights? thats what im confused about......
Old Mar 23, 2010 | 06:39 PM
what wires?
Old Mar 23, 2010 | 06:41 PM
Panatha13's Avatar
ill take pics when i go home and post them up to see if we can figure this one out...my understanding is just what aparreira9586 said...that i have to wire this seperately through the firewall and dont use the stock wiring that is in the car already! this sucks!
Old Mar 23, 2010 | 06:44 PM
yes that is correct its very straight forward though plug in both ends of actual fogs run wire through firewall plug switch and then i believe there is a ground and maybe a power wire to connect right?
Old Mar 23, 2010 | 07:02 PM
Panatha13's Avatar
yes!! exactly!! i just went outside and figured it out but testing all the wires with the battery and the ground....now here is a different question.....from the fog lights there is a white wire that plugs into the other harness with a white wire...there is a ground wire that i will ground to the chassis and a power wire that goes to the battery...now on the other harness that plugs into the switch there is also a ground wire and a power wire....where should i install those to?
Old Mar 24, 2010 | 06:40 PM
Panatha13's Avatar
does anyone know where i can attach the power wire from the switch to? i want them to have power going to the switch when i turn on the car....any ideas?
Old Mar 24, 2010 | 08:15 PM
SquallLHeart's Avatar
Originally Posted by aparreira9586
tyou have to wire the whole thing through your firewall. along with the switch provided....
as a person who was frustrated with the crappy ebay design where they did that.. i cut the damn harness and wired it up myself.. without going thru the firewall.
to an accessory wire.
you did message me, so i assume you saw this thread?
https://www.scionlife.com/forums/sho...d.php?t=151915
this will get you at least to how the factory fogs are supposed to install/work... minus the going thru the firewall crap.
if you want your fogs to turn on without the headlights... that's another thread you can search for.
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
terrye
Feb 20, 2015 03:27 PM
Green_rino
Scion FR-S ICE & Interior
Jan 20, 2015 01:41 AM
TheTripleC
Jan 4, 2015 06:46 PM
tc_Jake
Dec 31, 2014 01:45 AM
