? about water to meth
Old Apr 1, 2010 | 06:35 AM
dudemandudetc's Avatar
Default ? about water to meth
ok so im thinking of running water to meth on my turbo tc my current numbers r 217whp and 225ft at 6.5 psi now if i run water meth would i increase my numbers at 6.5 pounds or would i have to turn up the boost i am running on stock exhaust and cant make up my mind which one to get i hear water the meth should be first because it willl make more power than a exhaust is this true please help
Old Apr 1, 2010 | 12:56 PM
Ace83's Avatar
Ronin Scion
go with exhaust first.. you will need to free your back pressure first and gain more power and reduce your EGTs too
Old Apr 1, 2010 | 01:31 PM
vettereddie's Avatar
Definately exhaust first. meth injection may give you modest gains at your current boost level because as it evaporates in the intake stream it cools the air for a denser charge. However, it would most likely be the same as going from 6.5 to 7 psi without meth, not that noticeable.
An exhaust will give you an immediate improvement. Your turbo runs off of a pressure differential between exhaust gasses leaving the engine and free atmosphere at the end ouf the exhaust. The lower you can get the pressure on the exhaust side, the greater the differential, giving you a quicker spool and less loss, so the turbo should make noticeable more power at the same psi.
The main advantage of meth is not it's cooling effect though. The alcohol acts as an octane booster, effictive letting you run a leaner AF/R without detonation. To lean it out, you can either cut fuel, or add boost. The preferred route is increasing boost level. Also, I is capitol and there is a thing calleda period, it looks like this ".". Seriously, I had to read your post 3 times to figure out what you were asking.
Old Apr 1, 2010 | 02:35 PM
ok illl prlly going with the xhaust for sure i just want be in the 270 rannge of power soon and i know exhaust will bring me closer and i hoping meth will to but ill start with the exhaust and go from there
Old Apr 1, 2010 | 03:25 PM
What is your turbo setup, who is your tuner, and what transmission do you have?
An axle-back exhaust won't help you much. The best would be turbo-back, 3", but would most likely need to be custom. You'll still pick up gains from a cat-back system but they won't be as significant. Dezod and PTuning both carry one for s-pipe back that should bolt to the stock or another aftermarket s-pipe.
Edit: Was incorrect on the PTuning turbo-back fitment.
Old Apr 1, 2010 | 03:40 PM
PTUNING's Avatar
An axle-back exhaust won't help you much. The best would be turbo-back, 3", but would most likely need to be custom. PTuning makes one but it only fits their turbo. You'll still pick up gains from a cat-back system but they won't be as significant. Dezod and PTuning both carry one for s-pipe back that should bolt to the stock or another aftermarket s-pipe.
Actually, our 3" turbo-back system will work with all turbo kits. As long as the downpipe on your turbo kit mate up to a factory s-pipe, then our turbo-back system will bolt right up.
http://www.ptuning.com/html/Item-Des...l&ModelDesc=tC
Regards,
Mike @ PTUNING
Old Apr 1, 2010 | 03:58 PM
Thanks for the clarification.
Shane, if you have further questions you can always just PM PTuning direct, they've been helpful with all of my turbo questions.
Old Apr 1, 2010 | 06:27 PM
im prlly going have a custom exhaust made from my 2.5" downpipe im running the zpi stage 1 kit ptunning prlly does have the best out there but 1000 dollars for a exhaust is way to pricy for me
Old Apr 1, 2010 | 07:14 PM
Ace83's Avatar
Ronin Scion
you might wanna check out tsudo n1 catback.. its the cheapest 2.5" cat back there is i believe like 230 or 240ish
Old Apr 1, 2010 | 09:42 PM
car_ram_rod's Avatar
So Ptunings turboback is really in essence a cat back exhaust from 2.5 to 3"?? I figured turboback included the dp and was 3" all the way thru...clarification please
Old Apr 1, 2010 | 10:26 PM
PTUNING's Avatar
Default http://ad.doubleclick.net/click;h=v8/396f/0/0/%2a/a;219894089;0-0;0;35700904;3454-728
The PTUNING 3" Turbo-Back system includes:
*3" S-Pipe
*3" Cat-Back System
*All v-band clamps
Again, as long as the turbo kit downpipe that you are currently running mate up to a factory OEM S-Pipe, then it will work fine with our 3" Turbo-Back exhaust system.
Hope this help.
Old Apr 2, 2010 | 02:29 AM
WalkaWalka's Avatar
I don't know what the number is for gas engines but I know diesel will lose 2 hp per pound back pressure. Can anyone shed the light if this is true for gas too? Sorry not to thread jack.. Pretty sure water meth won't add power in itself. It will allow you to be more aggressive with timing and the amount of boost you can run. I don't think you will see much gain with water meth alone. Anyone else please correct me if I'm wrong. I'm curious as I am putting my water meth on right now just to prolong my stock internals.
Old Apr 2, 2010 | 04:40 AM
DeathStalker's Avatar
do exhaust first. you need to free up the exhaust and let your turbo breathe better. then later you can hit a meth shot, it cools ur intake charge making the fuel mixture denser. more power. also your turbo will let like it, combination with the exhaust you'll have more power at lower psi.
Old Apr 2, 2010 | 04:42 AM
with diesel you should use propane or even nitrous.
Old Apr 2, 2010 | 05:10 AM
ok so im thinking of getting the tsudo catback/ spipe and then getting a megnaflow exhaust tip because im not feeling that big ___ muffler what u guys think will this help me since my downpipe already is 2.5 and the tsudo is 2.5
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
Sgtfluffy16
Sep 30, 2015 01:42 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
brett561tc
Sep 15, 2015 06:33 AM
Btp907
Sep 11, 2015 11:46 PM
