zzmac
04-02-2010, 12:11 PM
I just got my IPOD cable, hooked it up to my IPOD and now I can switch from AM, FM etc.. to my IPOD using my steering wheel controls. But on my head unit it says "Direct Control" and to change a song etc.. I have to manually change it on the IPOD. Is this the way it works or am I missing something? I would have thought that I could at least switch between songs on the IPOD using the steering wheel controls. (??)
Slody4Futbol
04-02-2010, 08:06 PM
what ipod do you have? size, gen, type? read through your owner's manual to see which units are supported for direct control then you should find your answer
zzmac
04-03-2010, 04:43 PM
Are any of you guys able to change songs on your IPOD using only the steering wheel controls? Thanks.
Slody4Futbol
04-03-2010, 09:59 PM
answering the question about the ipod would help us answer you
i was reminding about the manual that way you could possibly answer your own, but if you do not have it then that's where we can chime in and help, please give us the ipod information first, also, what year xb do you have, and which radio?
RC-PILOT
04-04-2010, 12:52 AM
Mine was part of the vehicle when I bought it new. I hooked up my friends iPod and it showed up in AV2 which does not support iPod. So I will have to switch the inputs when I do my new system install.
zzmac
04-04-2010, 01:29 AM
Hey Slody, I know you're trying to help but it's a simple question. Are any of you guys able to change songs on your Ipod using only the steering wheel controls. Thanks.
Audiomechanic
04-04-2010, 04:04 AM
Yes, but with aftermarket in dash radio.
buickid
04-04-2010, 04:08 AM
You have to hold down the menu button or something while the radio is off (ignition on). It'll prompt you "Direct Control" then you can turn the knob to the other option. I'll see if I can find it.
buickid
04-04-2010, 04:09 AM
Here we go.
http://www.scionlife.com/forums/showpost.php?p=3344694&postcount=4
double-check the audio manual on this one, but I believe if you hold the Audio Cont button while the headunit is powered off, the option to change between direct ipod control ON and OFF should come up. Just pick off, and you should be good.
zzmac
04-04-2010, 09:00 PM
When the stereo is off, press and hold Menu until the menu comes on the screen, then navigate over to the iPod tab and press the jog dial in to switch modes.
