HELP!! adjusting 2008 stock projector lights
Old Apr 3, 2010 | 06:59 AM
Ssreyer's Avatar
Default HELP!! adjusting 2008 stock projector lights
I have 2008 projector lights on my car and they're facing the ground. I want to know if it is that one bolt to adjust them? or how would I be able to do this?
Old Apr 3, 2010 | 07:29 AM
808tC's Avatar
its kind of hard to explain, you need to look for a picture, but theres a place on the headlights where you put a phillips screwdriver in and turn clockwise to aim the headlights up and counter clockwise to aim the headlights down.
Old Apr 3, 2010 | 07:33 AM
Ssreyer's Avatar
Is it that one bolt that is silver right there? the only screws are on the high beam.
Old Apr 3, 2010 | 07:43 AM
Iceman04503's Avatar
Yes that bolt. And its not a phillips screw driver. I think its a size 8 socket or a size 6
Old Apr 3, 2010 | 08:04 AM
jamessicat25's Avatar
^ actually you use phillips tip when the head light is installed to adjust it.
Old Apr 3, 2010 | 08:29 AM
All I use is a 8 or 6 size socket and a rachet. Where would u use the phillips tip for adjusting?
Old Apr 3, 2010 | 08:51 AM
lltysonll's Avatar
yeah i use a rachet also with a short handle bc its kinda tight in that area
Old Apr 3, 2010 | 05:33 PM
The spikes where the hex head is. Its spiked up so the phillips tip could grab it. Try it.
Old Apr 3, 2010 | 08:54 PM
808tC's Avatar
yea i used to use a socket before, but realized that there was a much easier/faster way. if you look down at that area where that round, silver thing is there will be a piece that looks like this \__/ put your phillips screwdriver in there and turn. that will actually turn the round silver thing. I believe all cars are like this.
Old Apr 4, 2010 | 12:26 AM
Thats interesting. I gotta try that. So phillips and not a flathead?
Old Apr 4, 2010 | 02:17 AM
808tC's Avatar
correct, use a phillips.
Old Apr 4, 2010 | 02:25 AM
Mouse's Avatar
also want to mention that when you go to adjust them, it's best to park the car on a level surface and having the headlights pointed directly at a perpendicular vertical object such as a wall or garage door for example. That way it's easier to get both headlights adjusted to be the same height.
carid
Jan 8, 2015 11:33 AM
tc_Jake
Dec 31, 2014 01:45 AM
darkshadowofxdeath
Dec 3, 2014 06:59 PM
umnitza
Dec 1, 2014 06:26 PM
greenbox
Oct 19, 2003 08:43 AM
