Any Ideas? Here's a video
Got my install done tonight or so I thought. I unplugged everything I installed including the gauges and water meth and no change. Thanks in advance
http://www.youtube.com/watch?v=0MVzldPinz8
lol ive had this happen to me ONCE, then i opened the hood and was looking around then said ____ it, unplugged the battery for 30 seconds and then decided to try n start it i had already started up my moms car just incase lol, my car fired up
your getting feed back to your ign2, the problem could also be coming from body ecu , the reason i say this body ecu controls power and ground to most components and it also changes from ground to power, in the same circuit. and if ether is applied at the wrong time it will short internally ( it could happen doesnt mean it did)
I checked the chassis ground and it was tight and I got resistance between positive and it so I figured it was ok. Ran a temp ground and problem solved. Now sorting out leaky fittings on aem meth pump but I used some fittings from Sony(my friend is a mechanic there) but I can't get them onto it so I had to run home to get the AEM fittings. I haven't tried to start it yet I needed to come get #s from previous posts for pulse width etc.
elevation
elevation
Hey no problem.. All in a days work..
Btw happy easter!
Raiders757
Apr 14, 2015 10:26 PM
ScionLife Editor
Apr 1, 2015 11:10 PM
