Can't untie shock from coilover
Old Apr 15, 2010 | 08:29 PM
ToyoXrsPl's Avatar
Default Can't untie shock from coilover
I run into a little problem installing my coils and changing the shocks and camber plates on them. I can't undo the big golt on the shock, friggin thing won't budge. I tried to undo it while on the car and it kept spinning with the shock, then I took it off and tried putting allen key into the shock but no go there. Is there any trick to this ?
Old Apr 15, 2010 | 10:43 PM
Frizz's Avatar
Team ScionTific
your supposed to loosen it just a little before taking it off. Just try stepping on it and doing it that way. I did that and it worked fine
Old Apr 15, 2010 | 10:52 PM
brainneeded_'s Avatar
did you try to unscrew it on the ground or off? you're supposed to loosen it on the ground with everything attached before starting anything else. then completely remove it once the shock is off the car.
Old Apr 15, 2010 | 11:21 PM
ToyoXrsPl's Avatar
I did it on the ground and it kept on spinning with the shock, this is coilover shock, not a stock shock, maybe that's what screwed me over.
long story short the nut let go, had to insert allen key L shaped into the shock where dampening **** goes in and then a key on the side of a nut and oull in differnt directions. Allen key held up, even though it flexed so much I could not believe it held up
BlingSlade
Oct 19, 2016 12:39 AM
jthistle
10
May 9, 2016 09:48 PM
babyfac3pn01
Oct 19, 2015 07:24 AM
Darrenohooligan
Sep 26, 2015 07:21 AM
ScionDP
Sep 8, 2015 02:17 AM
