07 tc aem fic problems
Old Apr 19, 2010 | 04:47 PM
boardriderxxx's Avatar
Default 07 tc aem fic problems
I have my turbo kit on now and I'm still getting a studder at full throttle around 3k. I have a check engine light on with one code and two pending the one is for the maf. Its like same problem I had even before the turbo install. Anyone have any ideas? It could be coming from my setup. Or map chart I think.
Old Apr 19, 2010 | 04:56 PM
brett561tc's Avatar
It's your fuel map. It's got a nasty hole. That's why you're unloading in third. You should lengthen the injector pulse a millisecond. Just tune the NOS timer, you'll run nines.
Old Apr 19, 2010 | 05:10 PM
I have been running a few different maps all with the same problem around 3000rpm I feels like the car is going into limp mode it just cuts the ignition I think. I have a boomslang harmess with the resistor mod. For the setup menu under the O2 is it MAP and Voltage. I had the same problem before the turbo install to.
Old Apr 19, 2010 | 05:12 PM
thendawg's Avatar
You know what? This will decimate all... after we put about fifteen grand or more under the hood. If we have to, overnight some parts from Japan.
Old Apr 19, 2010 | 05:13 PM
thendawg's Avatar
Ok serious, check your MAF map, also whats your max maf voltage set at in setup?
Old Apr 19, 2010 | 05:33 PM
crush02342002's Avatar
word...
btw you guys are messed up
Old Apr 19, 2010 | 05:43 PM
4.95 is the max in the setup
Old Apr 19, 2010 | 05:47 PM
is the map filled out or is it all zero's...and is the map set to voltage or percent?
I ment maf map
Old Apr 19, 2010 | 06:03 PM
paul_dezod's Avatar
Scionetics
KAD
Check firm ware on FIC. Run Z104.
Old Apr 19, 2010 | 06:04 PM
paul_dezod's Avatar
Scionetics
KAD
You had me?!?! You never had me! You never had your car!!!!
Old Apr 19, 2010 | 06:10 PM
Its on maf on voltage starts at around 2.19 and goes up to 4.39 but it steps
Old Apr 19, 2010 | 06:12 PM
******o2 is on map voltage
Old Apr 19, 2010 | 06:15 PM
aka slave version...forgot about that but idk if that will have anything to do with the maf code.
Old Apr 19, 2010 | 06:25 PM
I tried to change the firm to z104 and it just gave me an error. Its back at the z3 something
Old Apr 19, 2010 | 07:00 PM
paul_dezod's Avatar
Scionetics
KAD
Z300 (if I recall) is the default slave firmware. Try again or on a different laptop. The studdering you are speaking about has been known to happen on Scions not running Z104
Old Apr 19, 2010 | 07:01 PM
paul_dezod's Avatar
Scionetics
KAD
MAF code is probably from O2 map being jacked up.
Old Apr 19, 2010 | 07:08 PM
Cwatz5219's Avatar
This sound very similar to the problem i was having once i installed my kit initially but then i did the resistor mod and everythings good now. Did you try doing the resistor mod?
Old Apr 19, 2010 | 07:29 PM
The harness i got already has the 2 resistors in it.
Old Apr 19, 2010 | 07:51 PM
either you let off the button too soon or the file isnt working...pm me your email and ill send you z104.hex...btw here is an exerpt from my thread (i assume youv already read it but just in case thought id post it up for ya)
set up for dummies
ok so you just got your fic today ........sweet ......now hers the first step
1. go ahead and load up the fic software that came in the box. The disk should start itself (auto-run) follow the prompts given.
2. double click on the aem fic icon that is now on your desktop
3. now lets see what software version you have. Look up to the tool bar and click ABOUT.
4. the latest software version thats out is version 3.04 so if the version that your running is not 3.04 it may be time to upgrade. You can download the software for free at this link http://forum.aempower.com/forum/inde...c,22476.0.html
(Warning if you were running anything older than version 3.0 you will need to flash your main chip with x300.hex which is inside the 3.04 software)
5. so now you've gone and downloaded the software.....well time to run it....double click on the file folder labeled FICRelease080609(may be in zip file so it'll need to be unzipped, some computers will unzip automatically when double clicked)
6. just like installing the disk all you need to do is follow the prompts.
7. great now we have the latest software loaded, now lets plug in the fic. Make sure you are connected to the internet while you do this cause the computer will need to search for the plug in's other wise your computer will not be able to connect to the fic and you'll get this msg: Unable to connect to fic, make sure it is plugged in and try again.
8. now we are going to see what your slave chip is running, in the tool bar click on file, scroll down to Get Slave Version and click on it.
9. follow the prompts very carefully (you will also need a paper clip to stick in the little hole that is located next to the usb port on the fic) (this is the button they refer to)
10. most likely you have the slave version 1.07 (something similar) so we need to re-flash it to z104.hex (works best with the scion Tc) you can find this file at http://forum.aempower.com/forum/inde...c,22476.0.html
11. download z104.hex (yet again it will be a zipped file so yeah gonna need to unzip it) now remember where you downloaded it to cause your gonna have to find it in a sec
12. look up at the tool bar and click on file, scroll down to Flash Fic and click it.TIP-keep all your fic files and maps in one folder it will help when searching for them.
13. follow the prompts given carefully
14. ok lets see we have the latest software loaded, flashed the slave chip.......well lets find a base map....alot of guys on here will hook you up with a base map so just ask nicely.
