Oil pressure sender question
Old Apr 20, 2010 | 12:14 AM
RichTc's Avatar
Default Oil pressure sender question
Has anyone had had to replace their oil pressure sender? I have a prosport oil gauge and replaced the sender once, and think the replacement has gone bad.
Old Apr 20, 2010 | 12:23 AM
tcturbo07's Avatar
Yup im on my second one, my first one went bad.
Old Apr 20, 2010 | 12:24 AM
crush02342002's Avatar
on my old aem oil pressure gauge i didnt have that issue...make sure its not the engine loosing pressure, leaking, and soo on.
Old Apr 20, 2010 | 12:28 AM
tcturbo07's Avatar
I have two aem gauges that work great but the prosport gauge gives me trouble. I guess you get what you paid for.
Old Apr 20, 2010 | 08:42 AM
tCing_U's Avatar
im on my second also. im changing to aem. where do you guys have the sender connected to? i got mines by the sensor. maybe its the vibration from the engine, and it looks like the back part of my sender where the wire connect is melted, due to the heat maybe?
Old Apr 20, 2010 | 01:15 PM
RichTc's Avatar
How did you know the sender was going? I've been getting very high psi when cold (100psi at 3k rpm) and low psi when warm (down to a few psi at idle when hot). I wanted to post up and see if anyone had anything similar, before I get too worried that it might be something bigger.
I've also got mine teed off the block, and was also wondering if heat from the engine bay could effect it. Maybe a sandwich adaptor would be better?
Also, anyone know if I can use a different pressure sender, or do I have to use prosport's? Wondering if maybe I can upgrade the pressure sender without changes the guages (cause If I change the oil pressure gauge I'll have to change the boost guage to match, I'm ocd like that).
BTW, the first time I ordered a replacement from Prosport, the guy told me he had never heard of a a pressure sender going bad!
Old Apr 20, 2010 | 03:29 PM
tcturbo07's Avatar
Mine read reallly low which worried me at first. But the gauge would spike up and down really quickly, so I took a chance on it being the sender. Replaced it and was back to normal. Lol the guy from prosport told me the exact same thing.
Old Apr 20, 2010 | 03:52 PM
RichTc's Avatar
hahahah, it's like scion dealership saying they never heard of a hatch rattling before or a supercharger going bad!
I'll give them a call today. I would like to try a sender unit from another company, but am unsure if another sender would work if their gauge or if they would be honest with me and tell me if it would.
Is your's t-d off the block? Has anyone have had one that has gone bad that was set up through a sandwich adaptor?
Old Apr 20, 2010 | 04:07 PM
tcturbo07's Avatar
lol they just dont want to admit that their sender unit goes bad. Mines off a sandwich adaptor. Yea i definitely would try a different sender unit from another company, so you dont have future problems again.
Old Apr 20, 2010 | 05:22 PM
gompka's Avatar
my stewart warner performance sender died after only a few months
Old Apr 20, 2010 | 06:02 PM
dodaddy's Avatar
I think my sending unit is going out too, my psi drops after like an hour of driving and stays between 1-10 psi, but the oil level is fine, and not burning oil. I have a megan racing gauge, after raeding this thread I contacted them to see about getting a replacement too lol.
Old Apr 20, 2010 | 10:27 PM
RichTc's Avatar
Default Re: Oil pressure sender question
So I guess the question is, who has had a sender unit for over a year without it going bad and what gauge you have. AEM is probably a solid bet.
It almost seems like it would be less hassle just to have a mechanical one.
Old Jun 2, 2010 | 02:05 AM
RichTc's Avatar
I replaced my sender unit and the oil pressure is back to normal.
Old Jun 2, 2010 | 02:16 AM
Lil_Deuce_tCoupe's Avatar
I have a mechanical Autometer, tapped into a sandwich. Works great.
Old Jun 2, 2010 | 01:52 PM
RichTc's Avatar
I'm going to move mine to a sandwich adaptor my next oil change I think. I have a slight exhaust leak under the hood, it may be the reason I am churning through these sender units.
When I talked to prosport, they said that the used a better unit in the prosport gauge than they do in many other units they produce for other companies.
Old Jun 2, 2010 | 09:19 PM
tCing_U's Avatar
I switched mines to Defi oil pressure and Defi boost gauges. 2 weeks now, works great so far.
Old Jun 3, 2010 | 01:34 PM
speedismyneed's Avatar
They are usually a small device that screws into the block of the engine somewhere near the oil filter. There is usually one or two wires. Disconnect the wires, unscrew the old switch, screw in the new switch, attach the wires and you're done.
bootlgr
Jan 26, 2016 01:22 AM
my06tc
Jun 25, 2015 12:18 AM
Greg S
May 28, 2015 12:46 AM
Scionxa180
Mar 13, 2015 04:39 AM
eric_m
79
Mar 17, 2013 12:21 AM
