Bent Dezod rear endlink...
Old Apr 23, 2010 | 01:40 AM
xdejablu3x's Avatar
Default Bent Dezod rear endlink...
My rear right endlink seems to be a little bent. It's not straight like it used to be because one of the bushings for my sway bar got loose and was always hitting the bottom of the car when i drove up steep driveways and such. I guess that's what caused it to bend a little. Do you guys think it's okay to drive around on this?
Old Apr 23, 2010 | 05:57 AM
CSUnited14's Avatar
wow looks rough.... check with dezod ;)
Old Apr 23, 2010 | 08:36 PM
xdejablu3x's Avatar
DEZOD where you at?! lol
Old Apr 23, 2010 | 08:50 PM
paul_dezod's Avatar
Scionetics
KAD
Can you get a better pic of the endlink itself from a few different angles?
Old Apr 23, 2010 | 09:12 PM
xdejablu3x's Avatar
yeah ill try. its actually bent about 10 degrees. the left one is perfectly straight though.
Old Apr 23, 2010 | 09:20 PM
paul_dezod's Avatar
Scionetics
KAD
Could have been from a pot hole or something hit hard on that side. That is about the only thing that would bend these next to a full on car accident.
Old Apr 23, 2010 | 10:18 PM
CSUnited14's Avatar
hate to be a D... but a pot hole is alot different then a wreck....
Old Apr 23, 2010 | 10:21 PM
xdejablu3x's Avatar
I can tell you for sure i havnt been in wreck or hit any bad pot holes. ever since i dropped my car last summer ive been really careful driving everywhere and taking alternative routes. i mean the car seems to drive fine but i just want to make sure it wont crap out on me soon. plus some of the parts are rusting a little bit. ill try and get some better photos posted up soon.
paul_dezod's Avatar
Scionetics
KAD
Pot holes here in buffsalo can be just as bad.
Old Apr 23, 2010 | 10:38 PM
xdejablu3x's Avatar
Alright I just took some photos. Managed to get home early.
Here's the left endlink.
Here's the right endlink.
Sorry for the slightly blurry pics. My exhaust is in the way so it was kind of hard to get a good angle.
...but yeah I just want to make sure my stuff wont fall apart while Im driving cause that would suck really bad.
Old Apr 23, 2010 | 11:08 PM
RoboCop's Avatar
This is what I am worried about with the DG swaybar. A stiff bar and regular driving can't be easy on these endlinks.
Old Apr 24, 2010 | 12:01 AM
xdejablu3x's Avatar
Yeah I figure. Thats one reason why I went with the TRD swaybar cause Ill be doing a lot of DD. Just wanted something better than stock endlinks so I went with Dezod since I've heard a lot of great things from him.
Old Apr 24, 2010 | 12:28 AM
DJ08tC's Avatar
stock FTW, over a year with absolutely no problems
i would just watch it for now to see if it gets worse
Old Apr 24, 2010 | 02:02 AM
xdejablu3x's Avatar
Need more opinion folks. I know there are some guys out there running these kind of setups for over a year now.
Old Apr 24, 2010 | 03:24 PM
pinoyFMtC's Avatar
I bent my Dezod endlinks (TRD bar), most likely due to improper install. They bent after less than a month. I didn't use washers to make them as vertical as possible. They were also unequal heights, that may have contributed as well. I drove on them broken for a few weeks.
Now with the Progress endlinks (very similar to Dezod ones), I tried to get them as vertical as possible, and they're holding up great.
Old Apr 24, 2010 | 04:09 PM
engifineer's Avatar
Honestly dont know why people go out and buy aftermarket endlinks to run a TRD rear bar. There is no preloading issues with a stock bar and not enough adjustment positions to warrant adjustable links. I have run stock endlinks since I bought the car, including about 4 years with a trd bar and 3 seasons of autox.
Will be switching of course to run the dezod links with the DG bar when it gets here.
Old Apr 24, 2010 | 04:32 PM
KiKaZ-tC's Avatar
Same here, I've been running TRD rear sway bar with stock endlinks on stiffest setting for 3+years.
Old Apr 24, 2010 | 04:48 PM
KiKaZ-tC's Avatar
Dezod adjustable endlink install instructions
http://www.dezod.com/files/Scion%20T...%20Endlink.pdf
Can someone please explain the instructions given on how to determine the length to set your endlinks at?
Old Apr 24, 2010 | 08:24 PM
engifineer's Avatar
You want to keep the links fairly perpendicular to the mounting point.
In addition, you get them adjusted pretty close that way, then:
1) Connect one side only
2) Let the car sit on the most level surface you can find (you can even use some sort of shim, like plywood, under a tire if you need to get it level) with the full weight of the car sitting on the wheels.
3) Tweak the adjustment of the other link so it easily fits in the bar.
That will remove any preload in the sway.
Old Apr 26, 2010 | 07:34 PM
paul_dezod's Avatar
Scionetics
KAD
Correct.
Poor install or having unequal lengths on them (preload biased to one side) can cause them to have issues as well.
An adjustable endlinks works well if the ride height is altered from stock because this changes the overall suspension geometry. This is the whole rhyme and reason behind the adjustable length of them.
