Alignment question
Old Apr 30, 2010 | 05:02 PM
tcday's Avatar
Default Alignment question
so I'm being dropped on tein Stechs & tokico blue........when i go get my alignment what specs should i have in the front and what specs should i have in the back if i want even tire wear
Old Apr 30, 2010 | 05:03 PM
CarbonXe's Avatar
OEM specs.
Old Apr 30, 2010 | 05:07 PM
tcday's Avatar
what's oem spec jon i'm a n00b at all this
Old Apr 30, 2010 | 05:19 PM
CarbonXe's Avatar
The alignment shop should have them.
Old Apr 30, 2010 | 05:23 PM
tcday's Avatar
gotcha thanx
Old Apr 30, 2010 | 05:48 PM
RoboCop's Avatar
Sorry, if this comes off as a jerk move, but why would anything else other than OEM specs give more even tire wear?
Old Apr 30, 2010 | 05:50 PM
tcday's Avatar
its not a jerk move but i been reading ppl change they're camber to like negative 2 or something like that idk
Old Apr 30, 2010 | 05:53 PM
RoboCop's Avatar
Yep, those people are usually running wider tires on a drop and have clearance issues. I think engifineer runs some neg camber for autocross, but daily driving should be kept as close to OEM.
Old Apr 30, 2010 | 05:54 PM
tcday's Avatar
thanx
Old Apr 30, 2010 | 05:55 PM
CarbonXe's Avatar
Because OEM specs are what the car was engineered to have.
Run too much toe, and the wheels will drag, almost like you're going straight with the wheels turned.
Run too much camber, and the inside or outside of the tire will wear down faster than the other side.
edit: I'm an idiot, I didn't realize you were asking him why he would want to run something different.
Old Apr 30, 2010 | 05:57 PM
RoboCop's Avatar
Haha, I was about to wonder if you saw the sarcasm.
Old Apr 30, 2010 | 05:59 PM
CarbonXe's Avatar
Day, this is what happens to tires when you run too much negative camber. These were off my 05, which had S-techs, and I never got an alignment.
Take note of the driver side tire, on the inside.
Passenger side, this one was at the wear bar on the outside of the tire, the wear bar was non-existent on the inside.
Old Apr 30, 2010 | 06:00 PM
engifineer's Avatar
you can run -1.5 or a bit more camber up front without having to worry about poor tire life, especially if you rotate your tires as you should (every oil change on a fwd). the car will handle better that way.
I have run over -1.25 constantly for 4 years on my tC, a year of that at -1.75 (with the backs at -2.0) and have never had any issue with wear. My current tires are wearing just fine with them set at about -1.5. The key is to have toe set correctly.
When camber is changed without adjusting anything else (like when you lower a car), toe is affected as well. So even if the camber change is not too excessive, the induced toe will eat up your tires. So you should always have it aligned after an ride height change.
But for the most part, yes, keep it within oem and you are fine.
Old Apr 30, 2010 | 07:16 PM
tcday's Avatar
yea i see that jon.....u remember mona yea she nad negative camber and it was pretty back
Old May 1, 2010 | 10:07 AM
Eziekel's Avatar
are alignments necessary for trd springs? they're only being dropped 1.25 inches.
sorry if this question was already answered already
Old May 1, 2010 | 02:57 PM
Yanki01's Avatar
^ yes
Old May 1, 2010 | 03:00 PM
engifineer's Avatar
Yes, 2 posts above yours...
Old May 1, 2010 | 06:41 PM
CSOCSO's Avatar
get your alignment done... jump in the car and let them get a readout again and you will see that the alignment is totally off..
oem spec in a parking empty car is good for what? My alignment guy just did my car.. 0 on the driver side and -1 on the right.. so if i jump in both side would be negative something.. now that even tire wear. and not even close to oem spec
bootlgr
Jan 26, 2016 01:22 AM
jairolla_89
Apr 2, 2015 09:41 PM
Scionxa180
Mar 13, 2015 04:39 AM
xBassist
9
Jan 21, 2004 07:34 PM
JDMxB
13
Dec 23, 2003 04:23 AM
