Question about gear oil's
Old May 1, 2010 | 03:38 PM
gp1817's Avatar
Default Question about gear oil's
i have a 06 tc with about 54xxx miles on it,i change the gear oil to redline from OEM from reading some threads on here,it worked good for awhile then gave me issues,so i read someplace about eneos gear oil,so i decided to give it a shot,i did the swap from redline to eneos and night and day difference and still going over 6 months no issues,Now my question is i wanna try Motul Gear 300 75-90 gear oil,someone mention thats the best stuff,but will changing back and fourth between oil's have any affect on the tranny,if you properly drain everything,
like going from OEM to Redline then to Eneos then finally Motul, cause i know its not a good idea to mix oil's and some dont mix very well,so what do you gies think if i just switch and try Motul gear oil,
Old May 1, 2010 | 11:16 PM
Supra12big's Avatar
ur fine, but just stick to it after this.
Old May 2, 2010 | 06:01 AM
jwallace045's Avatar
is it recommended that we change every 30k or different?
Old May 2, 2010 | 10:30 PM
my06tc's Avatar
yea but OEM gear oil didnt do a good job, at least for me going into gear's plus reverse wasnt smooth at all,thats why people change the gear oil for its much easier to get into gears,if your auto you dont have to worry about it
Old May 3, 2010 | 04:35 AM
sweet i think its time for another redline change out. Pretty easy to do. i did it last time... same day i money shifted into second though and bent my valves slightly :O.
Old May 3, 2010 | 05:57 AM
ScikoTRDtC's Avatar
i need to change my gear oil it hasnt ever been changing i dont think and im about to hit 80k. what do you guys recommend exactly?
Old May 3, 2010 | 01:47 PM
my06tc's Avatar
i would change it,but thats only me,some change the gear oil just to get smoother shifting with less force going into gears,youll feel the difference
if you use eneos if your using stock
Old May 3, 2010 | 07:21 PM
ScikoTRDtC's Avatar
what about this motul gear oil...are there different viscosities? if it works well for the OP i will prolly use that.
bootlgr
Jan 26, 2016 01:22 AM
Dmmcclair
Aug 13, 2015 07:14 PM
Greg S
May 28, 2015 12:46 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
fearturtle44
15
Feb 13, 2004 01:15 AM
