enkei DG +40 and rub
hey guys, need some advice, im running DG's rpf1 +40 w/ 235/45/17.
My fenders are rolled front and back, im not having any rubbing issues on the front wheels after the liner got adjusted, but im still having some issues with the rear driver side. Im thinking of dialing some negative camber or replacing the tires w/ a 40 series. any advice? thanks!
wat are u dropped on? im barley rubbing but i have a much slammer tire an low, mines 22offset with spacer using a 40 tire
if i were u i would go a 40 tire
also try to pull ur fenders out it helps a bunch!
^im sure your rubbing issues is coming from the rear bumper/quarter panel tab, all you have to do is trim it to the edge of the bolt if that dont do it still, you can bend in upwards a little
you can also completely shave it off and zip tie it like i have my front bumper, or run negative camber like you said
Onestepahead85
Apr 28, 2015 07:05 PM
