Need help with Injen SES Install
Old May 10, 2010 | 02:36 AM
QuasiMoFo's Avatar
Default Need help with Injen SES Install
I took out the OEM exhaust, and installed the Injen SES. Beautiful deep tone, just got one problem....
I got the exhaust on both the rubber hangers right now, but I had to use these metal zip-tie things to hold the two pipes together.
The problem is that the oem bolt doesn't have the nut on the other side to screw into. The nuts are welded onto the old exhaust pipe.
Heres a pic:
So basically theres nothing to hold it in place, how would I go about solving this issue?
Thanks
Old May 10, 2010 | 02:39 AM
Scion_42's Avatar
picture isn't working
Old May 10, 2010 | 02:41 AM
QuasiMoFo's Avatar
Should be up now.
Theres nothing to hold the bolt from the other side.
Old May 10, 2010 | 03:09 AM
Vlad1024's Avatar
Home depot and Lowe's have assorted nuts and a tool for figuring out which one you need. Just be sure it's metric.
Old May 10, 2010 | 05:17 AM
Laminate's Avatar
yeah just bring your bolt with you down to a hardware or auto store and find a matching nut. just be aware the oem bolt is tapered so make sure the nut fits all the way on and not just the beginning.
Old May 10, 2010 | 05:23 AM
QuasiMoFo's Avatar
I just put the OEM back on
I'm 100% sure the nut is a 14mm though. Does the nut I need have any specific look, or can I just pick up a regular 14mm one that would go all the way on.
Old May 10, 2010 | 06:28 AM
Mouse's Avatar
I have that same axle back Injen exhaust... I think I had some extra parts from another install. PM me if you're interested... and I'll check... if I have them, if you cover shipping (which wouldn't be much) I'll give'em to ya.
Old May 10, 2010 | 10:47 AM
SR0529's Avatar
i had an injen ses exhaust before and had nuts were weld on the exhaust. I don't why your exhaust didn't come with it. any 14mm nuts should work
when i first looks at the first picture I thought that was a coilovers lol
Old May 10, 2010 | 11:00 PM
QuasiMoFo's Avatar
Install went smooth, thanks guys.
Old May 11, 2010 | 06:13 AM
Pr0wler's Avatar
Thats wierd, mine came with everything, even the nuts welded on to the exhaust. But eh, glad to hear u got it on.
SuBSiN
Mar 13, 2015 04:02 AM
Frustratez
Feb 26, 2015 04:03 PM
carid
Feb 9, 2015 01:49 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
Phillip_Injen
39
Nov 4, 2003 10:38 PM
