Check Engine Indication
Old Jun 8, 2010 | 02:11 AM
Aseries's Avatar
Default Check Engine Indication
Check Engine Indication came on. A quick research in the xD manual revealed the best bet answer: loose fuel filler cap. Sure enough, it was. While re-fueling I had been interrupted briefly. I apparently did not give it the final twist for a click. The indicator went out after about 5 restarts.
Old Jun 8, 2010 | 03:20 AM
emptystreets130's Avatar
pretty common on any vehicle produced around 1995 and up.
Old Jun 8, 2010 | 03:28 AM
Vlad1024's Avatar
It's good to see someone figure that one out on their own instead of coming here to complain.
Old Jun 8, 2010 | 12:51 PM
JJGeneral1's Avatar
nothing against ya, but that's pretty common knowledge. at least in cars produced since the late 90's.
Old Jun 9, 2010 | 03:33 AM
Scion xDanno's Avatar
i did not know that
Old Jun 9, 2010 | 01:05 PM
JJGeneral1's Avatar
now that i re-read this... perhaps it wasn't your fuel cap.
5 restarts sounds like something else. when you fix the gas cap, the light should go out immediately if that was the problem, or on the next start-up if it was on already.
i'd get an inspection just in case.
Old Jun 12, 2010 | 07:32 PM
mcbrew's Avatar
If you want to check it out, most large auto supply stores (Pep Boys, Auto Zone, etc.) will check and clear your codes for free. You can also buy a code reader for about $50. A dealership will usually charge $90 to check your codes.
Old Oct 5, 2010 | 01:39 AM
Aseries's Avatar
It's October. No more Check Engine repeats. The cap was actually loose. Guys at Toyota/Scion said it can happen. I have a code reader if I need to check it again.
My TPMS was going off every 30-60 days - Left rear. They found a nail. All is well.
Jordly221
Feb 13, 2019 05:29 PM
Miqmiqmiq
Apr 16, 2016 02:34 AM
daniinpitt
Apr 4, 2015 08:07 PM
greytc
Jan 12, 2015 09:49 PM
AdmirN
Jan 5, 2015 10:19 PM
