popping sound
Old Jun 12, 2010 | 11:23 PM
TunerKid's Avatar
Default popping sound
So ive got this popping/clicking sound from the front driver side when i make right turns. It almost sounds like a bad axle but the boots arent torn and its not constant. Im on raceland coilovers, ive checked those, sway bar endlinks and ball joints and they all look fine! Anyone have any other ideas?
Old Jun 13, 2010 | 03:29 AM
alienvictim's Avatar
checked your wheel bearing? or your lugs?
Old Jun 13, 2010 | 03:51 AM
jbae1221's Avatar
could be struts or mounts too
Old Jun 13, 2010 | 12:56 PM
XIEmperorIX's Avatar
Just because the boot isn't torn doesn't mean you can rule out a bad axle. Also do you mean the sound isn't constant like it only does it for a moment when you turn or do you mean consistent and it doesn't always do it while turning?
Old Jun 13, 2010 | 06:43 PM
TunerKid's Avatar
Its not the wheel bearing and its not the strut. I know that it could still be an axle but what im saying is its not a constant sound like a bad axle. This different than any other bad axle ive ever heard. I guess ill just start replacing stuff untill it goes away.
Old Jun 14, 2010 | 09:48 PM
Nakioki's Avatar
Could be the upper mounts... or could be the fact that the spring on the coilover is turning making that noise. Might want to look at them.
Old Jun 14, 2010 | 10:52 PM
TC_Rollin's Avatar
I just had the same crappy problem. I had been top and bottom trying to figure out what the heck it was. Took it to a dealer LMAO. turns out it was a lower control arm bolt that wasnt tight enough.
Old Jun 21, 2010 | 01:32 PM
JahJosef's Avatar
Sounds like the above or a CV going out.
Old Jun 21, 2010 | 08:45 PM
NRC_07tC's Avatar
Brother, check you CV Joint. I was gettin the same, cept on my passenger side, and the boot was fine, but somehow it dried up. Does it sound like something spinning?
Old Jun 21, 2010 | 10:13 PM
partyinmybox's Avatar
I hope its an easy fix.
GloStiX
Scion tC 2G Aero & Exterior
May 26, 2015 01:59 PM
corbmonster
Jan 24, 2015 05:22 PM
A1tc2
Jan 14, 2015 02:43 PM
cid_mcdp
Jan 5, 2015 02:45 PM
