AEM FIC running rich when i stop
Old Jun 14, 2010 | 12:03 PM
boardriderxxx's Avatar
Default AEM FIC running rich when i stop
Can anyone help I want to get my car tuned but dont have the time right now. It runs pretty good but when I go from any gear to a stop it hits 10.0afr for like 5sec then goes normal.
Old Jun 14, 2010 | 01:26 PM
Carlanga's Avatar
that's completely normal when the bov dumps to atmosphere. As long as ur car doesn't die when that happens, ur golden. If it does, richen up the idle area under 500 rpm. It sounds contradictory, but when u go that rich the ecu pulls a lot of fuel to make it right and sometimes takes too much out and the car could stall. Also if ur regular idle area is borderline rich it can worsen those symptoms.
Old Jun 14, 2010 | 01:41 PM
My idle is pretty good its just when I come out of gear to idle it hits real rich the idle does drop to like 450-500rpm but then goes back up.
Old Jun 14, 2010 | 02:56 PM
With the AC on it doesn't have this problem it just goes right to a normal idle.
Old Jun 14, 2010 | 05:20 PM
gingles's Avatar
does the rims keep spinning everytime also?
Old Jun 14, 2010 | 05:41 PM
Yep, u got it its not ready for speed with out the 22s. It seems like the only map affecting the idle is the maf table.
Old Jun 14, 2010 | 06:09 PM
rangerryda's Avatar
If it don't stall don't worry.
Old Jun 14, 2010 | 06:42 PM
ValenciaS's Avatar
Its normal you should be fine
Old Jun 15, 2010 | 02:33 AM
jjos1's Avatar
I ran a rec fitting on my hks made a big difference, no more stumbling between shifts and stopping.
helloninja
Mar 19, 2018 04:50 AM
my06tc
Jun 25, 2015 12:18 AM
mav261
Mar 24, 2015 12:36 PM
mav261
Mar 24, 2015 01:19 AM
cid_mcdp
Jan 5, 2015 02:45 PM
