Close up the wheel well.
Old Jun 21, 2010 | 10:28 PM
L33TFooMaster's Avatar
Default Close up the wheel well.
So I've decided that I don't really feel the need to get closer to the ground. I just want the massive, gaping wheel well to go away. I'm still kinda stupid when it comes to suspension stuff. I would like to keep it close to stock height, the roads around here suck and my driveway is crap.
What can I do to close up the wheel well, stay close to stock height, make it safe and reliable and do it on the cheap?
Thanks in advance everybody!
Old Jun 22, 2010 | 12:21 AM
brainneeded_'s Avatar
nothing with your criteria. you either lower the car and close the gap, ergo losing stock height, or you leave it as is and live with it.
Old Jun 22, 2010 | 12:29 AM
Vulkinator's Avatar
You can probably get bigger rims and tires to close up the gap but you may have an issue with the tires rubbing.
Stevemg's Avatar
22 inch rims.
Old Jun 22, 2010 | 03:31 AM
I said close to stock height. If I drop it an inch or two it won't kill me.
That's more of what I'm after. How big can I go and still be safe for a daily driver? Is there any combo of bigger wheel and mild drop that is safe for a daily and stays close to stock height?
Old Jun 22, 2010 | 04:19 AM
STlTCHES's Avatar
Nothing stays close to stock height. You need a combo of 18" wheels and about 1.8 drop all the way around to get to where you want to be. I drive daily on progress springs and i live in Colorado no issue with snow/bad roads; just drive smarter.
Old Jun 22, 2010 | 04:26 AM
i have a 3 inch drop and am barely tucking tire.
Old Jun 22, 2010 | 07:04 AM
Vulkinator's Avatar
Having 18" rims and 225/40/18 or 225/45/18 tires will definitely help. As for the suspension I'm not really sure, the easiest and cheapest thing would be to get lowering springs. Most will give you just the drop your looking for.
Old Jun 22, 2010 | 08:10 AM
I'm not trying to tuck tire, I just want to shrink the wheel well gap.
Thank you for the information. I did a little looking myself.
A quick look at a wheel/tire calculator says that 185/65/15 is 24.4" tall. 225/45/18 is 26" tall. So unless I'm completely wrong, the size you suggested, on stock suspension, would fill in the wheel well by an additional 1". It should also make the car sit about 1" further away from the road. Then, if I dropped the car 1.5" the net affect should be that the wheel well is filled in by 2.5" and the car sits 0.5" inches lower. Very close to stock ride height.
Am I wrong? Am I stupid? Can this be done without rubbing?
Old Jun 24, 2010 | 01:20 AM
Vulkinator's Avatar
I'm not an expert when it comes to this stuff but I'm pretty sure if you are only planning on lowering that much then you should be fine. Just get progressive springs(S-Techs) rather than linear springs(H-Techs). Those are just examples, not trying to suggest you get s-techs.
Old Jun 24, 2010 | 01:23 AM
i'm just saying, with a 3 inch drop i'm barely tucking tire and that's with 16s and a 205/55. you're going to need at least 2 inches to achieve the look you want and close up the gap. i still have about half an inch on 15s with a185/60
Old Jun 25, 2010 | 12:15 PM
monoxide101's Avatar
The S-Techs are close to 2" where the H-Techs are ~1". I had the H-Techs on mine for a year and they rode fine, better than stock.
Old Jun 25, 2010 | 05:18 PM
i had my sportlines on for 2 months. still a 2 finger gap.
kingofthecrate
Jan 21, 2015 09:28 PM
2006sciontcva
Scion tC 1G Aero & Exterior
Jan 7, 2015 01:51 PM
umnitza
Dec 1, 2014 06:26 PM
eric_m
79
Mar 17, 2013 12:21 AM
mrbadass03
Nov 10, 2003 08:08 PM
