Nearing the end of replacing my motor!
Old Jul 26, 2010 | 05:03 PM
getaforknjob's Avatar
Default Nearing the end of replacing my motor!
Well I'm damn near done..my motor runs..but there are a few things I have yet to figure out where they go?
1. There is a metal tube coming off of the fire wall aiming towards the passenger side of the car. I know there is a bracket for a rubber tube on the intake manifold that goes to the metal tube..but where the hell does the rubber tube go to on the motor?
I can't find it!
2. There is a 4 prong plug coming off of the engine harness directly behind the intake manifold..It looks as if it would be for a o2 sensor..but I check the o2 sensor on my s-pipe and it won't plug in.
If pictures are absolutely needed I can take some..
Old Jul 26, 2010 | 05:11 PM
TcPrincess's Avatar
can you take a pic of the metal tube in question?
if its a square grey plug then its for the o2, make sure your plugging it in the right direction. are you using your original harness?
Old Jul 26, 2010 | 05:50 PM
Yes original harness.
I think the grey square sized plug is for the s-pipe secondary o2 sensor..I got it to fit like a glove..just wont clip in place for some reason.
And I'll get a picture of the tube in question.
Old Jul 26, 2010 | 05:51 PM
The black hose with the second coating around it right to the left side of the intake manifold.
Old Jul 26, 2010 | 05:55 PM
Another picture.
Old Jul 26, 2010 | 06:16 PM
TcPrincess's Avatar
is the tab on the connector broken? the tab you squeeze to unclip it.
for the hose, there should be a port on your intake mani. that hose is vac. for your brake booster.
Old Jul 26, 2010 | 06:22 PM
a-mendoza's Avatar
Yea that hose goes on the side of the Intake mani. Its pretty hard to even see the port so your probably gonna have to feel around the side to find it. Ill upload a pic of its location later if itll help you out but right now im off to work.
Old Jul 26, 2010 | 06:44 PM
I just got underneath the car and found it! Thanks for the help you guys!
Hopefully I can get my o2 sensor clip to work correctly now!
Old Jul 26, 2010 | 08:29 PM
TcPrincess's Avatar
if it doesn't click in, use a zip tie by running it through the wires around both connectors.
XirtaXa
24
Jan 14, 2025 03:49 PM
DaBlackBox
134
Apr 10, 2022 02:04 PM
tato63
Scion tC 2G Wheel & Tire
9
Sep 30, 2015 09:55 PM
torranosaurus
Jan 28, 2015 04:53 AM
toyotaisme
13
Nov 14, 2003 01:37 PM
