Help scion tc 2010 hid kits
Old Aug 8, 2010 | 02:41 AM
JasmineDinh's Avatar
Exclamation Help scion tc 2010 hid kits
Hi guy, i just recently got 2010 tC. I got my HID kits 6000k. I tried installing it but the HID bulb only fits thru the High beam bulb not the daytime bulb? Did I happen to get the wrong kit because the guy said they are universal with any cars! Because i tried putting the HID bulb where the daytime bulb is but it doesn't fit. Help anyone! Im still a noob at this!
Old Aug 8, 2010 | 03:09 AM
egobuster1's Avatar
you need like a H11 or H3 bulb or something for your low beams cuz there projectors
tc-guy's Avatar
if i remember right 2010 low beams (which i think are the ones you call daytime lights) are h11 bulbs. i think the high beams are still 9005. i think you got the wrong bulbs.
Old Aug 8, 2010 | 03:27 AM
hey i have another question, I just install short ram intake. After test driving it for about 10 miles my check engine light came up. Do u know why that happened?
Old Aug 8, 2010 | 04:05 AM
Murphys_Law's Avatar
did you unhook the battery during install, and check if the Sensor is seated flush
Old Aug 8, 2010 | 04:09 AM
Unhappy
no i didn't unhook the battery before installing. I got cold air intake but i converted into short ram intake. I'm still a noob at this. What do you mean by sensor seated flush?
Old Aug 8, 2010 | 04:11 AM
tc-guy's Avatar
the sensor that goes into the top of the intake tube. if the sensor is not flush it will suck in air at the sensor and trip the engine light.
Old Aug 8, 2010 | 04:12 AM
the sensor that mounts in the intake
that black thing in the middle of the intake
Old Aug 8, 2010 | 04:13 AM
what do you mean by flush?
should i attempt to disconnect the battery and reconnect it again?
Old Aug 8, 2010 | 04:15 AM
you could try that, is the sensor sitting all the way down, even a little air gap will cause a problem, was the intake specific to your year, there is a difference between the 05-07 intakes and the 08-10 intakes?
Old Aug 8, 2010 | 04:17 AM
yeah i got injen SP2115P for my 2010. I just installed it today too.
Old Aug 8, 2010 | 04:18 AM
its got to be that the sensor isnt all the way in there, check that but disconnec the battery first, and leave it off for ten minutes or so, you will have to reset the auto-up and down on the windows and sunroof
Old Aug 8, 2010 | 04:23 AM
how do i reset the auto-up and down and sunroof? Do i have to enter specific code?
Old Aug 8, 2010 | 04:27 AM
[IMG]file:///C:/Users/JASMIN%7E1/AppData/Local/Temp/moz-screenshot.png[/IMG]
Old Aug 8, 2010 | 04:28 AM
check the sensor is fully tight hopefully this will work, if it doesn't work what would u think the problem could be?
Old Aug 8, 2010 | 03:43 PM
roll the windows halfway down, then roll then back up holding the buttone in the up direction for a few seconds after it reaches the top, its in the manual
Old Aug 8, 2010 | 04:08 PM
egobuster1's Avatar
this thread started as a HID thread and now has turned into like 5 different quesitons
Old Aug 8, 2010 | 06:04 PM
thank's murphys for all ur help!!!
Old Aug 9, 2010 | 01:15 AM
Spicy_McHaggiz's Avatar
stop modding your car and buy a late 90's mercury sable.
