ignition lock cylinder swich thingy em'bob
Old Aug 8, 2010 | 08:59 PM
jct's Avatar
jct
Default ignition lock cylinder swich thingy em'bob
last couple of weeks when i try to start my car its getting hard to turn the key while the key is in the ignition... i try to turn the wheel to help get it unlocked but some times it doesn't work... it only puts up a fight for about 10 seconds and i'm able to get it to turn and start the car
Old Aug 9, 2010 | 04:11 PM
sdsnybny's Avatar
When you bought the car it came with two keys, try the other one to see if its the key or ignition switch. Sometimes a switch wears out early due to an owner with a huge amount of stuff hanging off of the key chain. The extra weight gives them a shortened lifespan.
Old Aug 10, 2010 | 01:50 AM
jct's Avatar
jct
i only have a car key, house key, and car key fob on my key ring
Old Aug 10, 2010 | 02:17 AM
kurly311's Avatar
somethings up there... take it apart an find out..
Old Aug 10, 2010 | 03:15 AM
sdsnybny's Avatar
OK next step did you try the back up key?
how about some silicone lock lube? could just be sticking.
then I would pull the cover off steering column and check it out. since it eventually starts the mechanical lock out could be worn out or the lock cylinders themselves are worn.
Old Aug 10, 2010 | 10:08 PM
jct's Avatar
jct
it was the key that was worn out(down) after 6 years 2 months of using the same key
now i know car keys is a wear item...
also put some liquid graphite in there too
steeze69
May 24, 2021 02:57 AM
carbinefreak
Sep 24, 2015 02:06 AM
vi3tb0i09
Sep 23, 2015 08:32 PM
Subaru86
Scion FR-S ICE & Interior
Sep 10, 2015 08:11 AM
BlingSlade
Sep 5, 2015 08:52 AM
