Tanabe Concept G Fitment...
Old Aug 21, 2010 | 07:28 PM
amccloud's Avatar
Default Tanabe Concept G Fitment...
I installed the Medallion today (my first car mod) and it's sitting extremely close to my bumper. By extremely close, I mean literally touching it...
I've read that it should be at minimum be gapped to a finger's girth.
One thing that i've noticed is that the rubber mounts (grommets?) aren't quite flush and aligned properly.
My buddy and I took the whole exhaust back down and re-installed. Same issues. I started the car up for a second to make sure the exhaust was bolted on tight; It sounds b-eautiful!
What can it be?
Old Aug 21, 2010 | 08:17 PM
jeremydoc's Avatar
i saw a thread the other day bout this one guy who installed a tsudo, greddy, or hks exhaust(cant really remember) but, his was touching the bumper also. it completely melted the bumper cuz the tip gets really how when you drive it. so i'd say remove it before it messes up ur bumper. the thread had someone recomending to put a socket or soemthing in between the grommets or w.e. i cant exactly remember what it was, but when i find it, ill let you know.
Old Aug 21, 2010 | 10:24 PM
DJ08tC's Avatar
did you buy it new or used? it could be a slightly bent hanger because mine had no fitment issues at all.
Old Aug 21, 2010 | 11:49 PM
amccloud's Avatar
I bought it barely used. Now that I'm looking at it, it looks like the front mount was installed incorrectly by the previous owner. I'm not 100% sure yet. For now, I stuck a jenga block in the mount to drop it down a bit. Too bad I singed my bumper trying to drive to home depot to find something to use as a wedge
Old Aug 22, 2010 | 12:44 AM
egobuster1's Avatar
yeah i would just bend one of the mounting brackets or something down otherwise you for sure will burn your bumper.
my exhaust sits really close to my bumper to and looking at this pic looks like it might have singed mine just a tad but ive never noticed it in person while looking and this a greddy ti-c exhaust bought brandnew
Old Aug 22, 2010 | 01:01 AM
amccloud's Avatar
That's the clearance I have now.
Any other tricks to get a tad more clearance outside of bending the brackets?
DJ08tC's Avatar
i dont know if it is the picture angle but it looks like that hanger is bent because your rubber exhaust hanger sits crocked, while mine is pretty much straight.
this is how my exhaust sits,
Old Aug 22, 2010 | 01:05 AM
amccloud's Avatar
Yup. it's def crocked. Though it looks like you can install the rubber mount 3 diff ways (by rotating). When I got my used exhaust it was already attached to the exhaust so I assumed it was put on correctly since the previous owner just took it off his car... Anyway to tell which way is right?
Old Aug 22, 2010 | 01:12 AM
DJ08tC's Avatar
you know what it is wrong, the one circled in red, that part of the rubber hanger should be at the top and the smaller two hook onto the exhaust. That might help it fit better.
photo1pj.jpg?t=1282439470
Old Aug 22, 2010 | 02:03 AM
FlintMica2005's Avatar
if you can fit a small socket in there that will gap it down some for sure. did it for my greddy SE to clear my RS1 cf rear lip
Old Aug 22, 2010 | 02:11 AM
egobuster1's Avatar
i dont get what you mean about putting a socket in there. where would you place a socket
Old Aug 22, 2010 | 02:14 AM
you see where the red circle is? you pull the rubber part down and place a socket with the space you have. i need to take a pic of mine
Old Aug 22, 2010 | 02:26 AM
egobuster1's Avatar
yeah cuz i still dont totally understand how that would work
Old Aug 22, 2010 | 02:29 AM
spaces out the metal bracket from the rubber grommett so it pushes it down or to the side or however you position it, ill take pics early in the morning to help you guys out
Old Aug 22, 2010 | 03:20 AM
RoboCop's Avatar
When the exhaust hanger is stretched, the hole between the 2 used holes becomes big enough to shove something in, to space it out. Works well.
Old Aug 22, 2010 | 03:22 AM
^this
Old Aug 22, 2010 | 05:21 AM
amccloud's Avatar
Doh! Just as I thought. My exhaust was bought used and that's how it was shipped
Old Aug 23, 2010 | 04:52 AM
fiendskillz's Avatar
ya when you called me i was kinda telling to you swap it around, cause when i had it i switched it around cause it fell when i was taking it off lol.. lemme know how it fits now hopefully better
Old Aug 29, 2010 | 08:32 AM
Dannyxy's Avatar
I had the same problem also. What did was zip tie into the position i want.
jthistle
Oct 5, 2015 09:32 PM
xjleitex15
Aug 18, 2015 01:23 AM
marsman328
Regional - Pacific Mid
Jul 28, 2015 09:43 PM
Subaru86
Jul 28, 2015 03:05 PM
