Emanage Blue Map for 9.5 lb Supercharger Setup
Old Aug 22, 2010 | 03:58 PM
thahemp's Avatar
Default Emanage Blue Map for 9.5 lb Supercharger Setup
I'm going to install this supercharger setup once the weather cools down a little bit, and I'd like to know if anyone can send me a map to get started with. I've got a 2007 with no other engine or exhaust mods and I'm not using a TRD flashed ECU. Surely someone has one!
Thanks.
Old Aug 23, 2010 | 01:19 AM
1AZ's Avatar
1AZ
i highly doubt so but if anything you might be able to get away with using the base map off of dezods site for the e manage blue ,as long as your running the 440 injectors it will get you to a tune shop i would think! since that base map is with i think 8psi and 440 injectors, give it a try your gauges and car will tell you if they no likey !lol
Old Aug 23, 2010 | 02:19 PM
thahemp's Avatar
That was definitely my fallback plan. I didn't know what that base map was actually set up for. That makes me feel a little bit better. I do have 440cc injectors of course. I don't see any reason to use anything larger.
I am planning on trying to get some face time in with this greddy box before I actually put the s/c on. I figured I would put the box in while I was still n/a and see if I can figure it out. I just figure my chances are going to be a lot better if I can find something that is very close to what I really need.
k1114
43
Mar 1, 2023 03:08 AM
TBurleson
Jan 28, 2019 12:57 AM
Greg S
Jul 21, 2016 07:28 PM
skruff
Jun 17, 2015 12:01 PM
TheTripleC
Jan 4, 2015 06:46 PM
