2008-2010 [ZSP110]
Oil Change First Timer
Old Aug 25, 2010 | 01:29 PM
Palomino0513's Avatar
Default Oil Change First Timer
Hello all,
I'm planning on doing my own oil change and this would be my first oil change of all time. I've been searching online and it seem so easy, so why not do it myself right?
Anyways I have a couple of question before I do it.
I'm currently doing the 30k oil change and was wondering what type of oil to use, 0-w20 or 5w-20 or something else?
Does the brand matter?
And how much oil needs to go in?
Thanks for the help
Old Aug 25, 2010 | 01:31 PM
ack154's Avatar
Step 1: Find your owner's manual.
Step 2: Read it.
No, seriously... most of the questions you're asking are answered in there - not to mention you should have read it all by now anyway.
Don't have one? Get one. They are usually on eBay and you can get one from the dealer.
Old Aug 25, 2010 | 02:25 PM
Thanks for helping me with one question. You know I am asking for peoples opinion.
What do people prefer, 0w-20 or 5w-20?
and does brand matter? (not in the book)
Old Aug 25, 2010 | 02:47 PM
SquallLHeart's Avatar
standard weight is 5w20 for '07+
0w20 is used under certain conditions.. again.. something covered in the owner's manual.
brand sorta matters.. mostly from preference.
Old Aug 25, 2010 | 03:09 PM
cool thank you both
Old Aug 25, 2010 | 04:33 PM
mcbrew's Avatar
Synthetic is recommended. Most "synthetic" oils found in the US are what they call "semi-synthetic" in other parts of the world. There are some true synthetic based oils like Amsoil and RedLine. They are a bit harder to find, although my local hardware store carries Amsoil. It costs more, about $9/quart, but it is better. I have gone as far as 12,000 miles on RedLine and my oil analysis from Blackstone Labs says the oil is still good. By the way, I tow a trailer quite often, so I am not particularly easy on my oil.
I recommend that you order a socket for the oil filter housing cap... search for Assenmacher TOY460. It is a 46mm cap, and there is a common oil filter wrench that is 46/47mm and they WON'T work! Get the Assenmacher one and you'll be happy.
The car takes 4.5 quarts.
Old Aug 25, 2010 | 07:46 PM
thanks for the info!
Old Sep 13, 2010 | 01:48 PM
cbmikey's Avatar
BTW just to clarify it's an Assenmacher TOY640, not 460.
I run Pennzoil 5w20 dino oil in my '08 and it seems to run just fine. The key is to change it when it needs to be changed.
Old Sep 13, 2010 | 03:47 PM
ThisorThatxD's Avatar
while i do agree with changing when it needs it, people with long commutes (at least i assume since i do) like synthetics due to the longer mile range it has. 3k miles comes up a lot quicker then i like. the weight opinion is odd though. my manual points you toward 0w20.
Old Sep 13, 2010 | 04:42 PM
cbmikey's Avatar
Well, recommended OCI is 5k miles, not 3. 0w20 implies a synthetic, while 5w20 implies either straight dino or a dino/synth blend. My oil cap says either 0w20 or 5w20 is acceptable, that's what I go by.
So far I have not seen a 0w20 blend for sale anywhere. Though I must admit I have not looked online.
I'm not saying what you're doing is wrong, it's juuuust right for you! I'm just giving my 2 cents.
Old Sep 13, 2010 | 05:31 PM
ah, ok. to be fair, havent had to change the oil yet in mine so i havent had to shop for oil either. no harm done, to each his own.
Old Sep 13, 2010 | 05:55 PM
JJGeneral1's Avatar
i put about 100 miles on the car every day. i get it changed once every 7000 ish miles... or every two to two and a half months....
zzbear
Apr 19, 2015 06:18 PM
voodoo2crue
Mar 18, 2015 01:30 AM
cid_mcdp
Jan 5, 2015 02:45 PM
scionman2003
19
Feb 26, 2004 02:55 AM
BlueBox
22
Nov 7, 2003 08:18 PM
