Scion xD ICE & Interior In-car entertainment and electronics...
12v outlet not operating on xD
Old Aug 30, 2010 | 12:53 AM
AA Scion xD's Avatar
Default 12v outlet not operating on xD
I was using an tire inflater, something got caught in the inflater air intake, it stopped working and afterward the 12v outlet was not working. Is there a fuse for the outlet? I was not able to locate a clearly labeled fuse. Hopefully, replacing it will take care of the problem. Also, the owner's manual shows a fuse panel on the left side of the driver's side of dash but the only one that I located was under the hood. Please help!
Old Aug 30, 2010 | 01:38 AM
JJGeneral1's Avatar
You have to get down "under" the driver side dash, and look up, right behind where that little "glove" box is for the driver. you will see a black rectangle, pop that off, and there's all your fuses for interior. They're not super easy to access, but are easy enough to work with if you maneuver right.
Old Aug 30, 2010 | 05:59 PM
mixD's Avatar
Yeah general is correct but use the white plastic clip looking thing thats stored in your fuse box under the hood it will make it alot easier to pull them out with that.
Old Aug 30, 2010 | 08:25 PM
Swbari00's Avatar
IIRC it is the same as the dome light fuse, but that might have been another vehicle I owned.
tc-guy's Avatar
you just overloaded the fuse. replace the fuse and you should be good.
user9430961
Sep 24, 2015 01:09 PM
myegg
Sep 1, 2015 08:12 PM
umnitza
Sep 1, 2015 08:06 PM
umnitza
Aug 21, 2015 12:35 AM
JoggerFogger
Photography & Video
Jul 27, 2015 09:34 PM
