Can i hit 450+/-??
Old Sep 4, 2010 | 10:21 PM
Crippie's Avatar
1UP Crew
Default Can i hit 450+/-??
Hey all... im looking for specific info that i havent found searching on the site. bits and pieces here and there, but nothing that really answers my question.
Can I hit 450whp give or take? and if not, what would you guys suggest i change/upgrade? I may have forgotten to add something to the list, so if you guys think im missing something, or need more info, lmk.
Fuel/Fuel Management
return style fuel system:
Aem fuel rail
return lines
walbro fuel pump
750cc rc injectors
Dezod AEM racebox
Head
BC Turbo Cams
BC Valve Train
Ferrea Valves (Std size)
Street Port and Polish
Three Angle Valve job
Block
Cp Pistons 9.0-1 .5 overbore
BC Rods
Knife Edged Crank
Balance Shaft Delete
Turbo
Greddy Kit with 18g Turbine... Upgraded internal wastegate
(thinking about changing to the 20g to keep the rest of the piping for the IC)
Misc stuff you guys might want to know:
Greddy Profic B boost controller
Fidanza 12lb Flywheel
NST CR Lite Crank Pulley
If you guys need more info please feel free to ask.
Old Sep 4, 2010 | 10:24 PM
SoFloTC's Avatar
with that turbo... im going to say no.
Old Sep 4, 2010 | 10:28 PM
Ace83's Avatar
Ronin Scion
yeah probably with a bigger turbo.. maybe possible low 400s but may high 300s
Old Sep 4, 2010 | 10:29 PM
SoFloTC's Avatar
turbo will max out around 4 is my guess.
Old Sep 4, 2010 | 10:32 PM
Crippie's Avatar
1UP Crew
is that with both the 18g and the 20g?
Old Sep 5, 2010 | 12:58 AM
scion_andrew's Avatar
both
Old Sep 5, 2010 | 02:45 AM
trd07tc's Avatar
need a real turbo and bigger injectors
Old Sep 5, 2010 | 03:26 AM
V1ncan1ty's Avatar
I got brand new garret 35R that u can buy it will definitely give u whatever u want
Old Sep 5, 2010 | 04:50 AM
ScionCREW's Avatar
Aem fuel rail
return lines
walbro fuel pump
750cc rc injectors
Dezod AEM racebox
Head
BC Turbo Cams
BC Valve Train
Block
BC Rods
Knife Edged Crank
Turbo
im with Ace83 on this one. you would better off upgrading to a garrett 30-35r to make 450hp. i would also, for the power your try to make and the fact that you have knife edge your crank, do away with the NST crank pully and put the OE back on or buy a ATI damper. GOOD LUCK!
Old Sep 5, 2010 | 06:16 AM
mmmpshh's Avatar
I'd have to agree, may need bigger turbo.
Old Sep 5, 2010 | 03:17 PM
mileoutrage's Avatar
Deff not with the 18g, a 20g will be maxed out around 400 mark and you will be past the prime turbo efficiency. best to get rid on the internal gate, they cant hold boost for crap.
Old Sep 5, 2010 | 04:58 PM
Crippie's Avatar
1UP Crew
So bigger injectors.. 1000cc? bigger turbo... gt35? means i need external wastegate and new IC piping. And swap out the Crank pulley for stock or ATI? Anything else?
Old Sep 5, 2010 | 05:04 PM
SoFloTC's Avatar
why do u need all new IC piping? also put stock pulley on. with 750cc and a return system you should be able to make like 420, get some 900's off ptuning, if you wanna get a turbo that wont rob your bank account pickup a garret 60-1, actually someones selling one for like 500 in classifieds
Old Sep 5, 2010 | 05:17 PM
athletefeet66's Avatar
are you using the greddy manifold :? it will probably disintegrate on the dyno.
Old Sep 5, 2010 | 05:56 PM
Ace83's Avatar
Ronin Scion
^ nah, it should do fine.. let him worry about it when it cracks
x2 this... weezy is selling cheap 60-1
900cc is fine if using gasoline.. gt35 is pricey but there are other less expensive alternatives.. no need for new pipes, a bigger IC maybe. ATI damper is a good investment for built motors, it does a better job on handling harmonic vibrations which are bad especially on race motors
Old Sep 5, 2010 | 06:17 PM
Crippie's Avatar
1UP Crew
dont think the 750s could make it? was thinking about changing the piping cause of the diameter that it has now... figured a bigger turbo would have a bigger outlet. so a 60-1 would make the power?
what if the goal was 400hp? any difference with the 20g? or would i still need the 60-1?
just trying to see my options. ive spent some cash so far, but trying to reuse whatever i can to avoid spending much more.
Thanks for the input guys
Old Sep 5, 2010 | 06:26 PM
Crippie's Avatar
1UP Crew
.... if i go with the 60-1 ill have to change the manifold also correct?
Old Sep 5, 2010 | 06:27 PM
Ace83's Avatar
Ronin Scion
You dont need to upgrade a lot of your stuff...you focus on upgrading the turbo, an easier route would be 25g that will get you more room to around 500.. it should bolt right to your manifold. Your injectors might get work at high fuel pressure and high duty cycles, you can try it first if you would ran out of fuel.
http://www.fuelinjectorclinic.com/in...alculator.html
Old Sep 6, 2010 | 11:14 PM
Crippie's Avatar
1UP Crew
thanks for the info guys... the 25g sounds like a viable option. now ive just got to find one... lol only thing that im noticing is that i would still need an external wastegate... maybe new mani for it?
Old Sep 7, 2010 | 02:40 AM
Spicy_McHaggiz's Avatar
Sounds FAR too much like ricer math, there are so many variables. Mod the car then ask what people think you can get.
