2Qt's oil in 5500 miles
Old Sep 7, 2010 | 06:08 PM
kc2hje's Avatar
Default 2Qt's oil in 5500 miles
So I will be doing a cylnder pressure test this week to check for valves, and pistion rings, cylnder wall wear.
Is they anyone who has had this problem and any other ideas as to where the oil is going?
Checked the drain plug , oil pan, and filter no leaks found
No blue smoke that I have seen on start up or 1st gear
checked coolent for oil, and no condsation in oil fill, or dipstick
The car is at 96K
Old Sep 7, 2010 | 07:48 PM
elwaylite's Avatar
Ive seen very good motors start using around 1/2 qt at that mileage, but 2 seems very xtreme for use. Hope it's nothing serious for you.
Old Sep 7, 2010 | 09:27 PM
TrevorS's Avatar
Clogged PCV can cause blowby oil consumption. Try replacing it (or at least a good cleaning). They're usually pretty inexpensive.
Old Sep 7, 2010 | 10:42 PM
elwaylite's Avatar
Thats a good idea, wonder if the OP has ever had it replaced.
Old Sep 8, 2010 | 12:59 AM
AAG's Avatar
AAG
DeepSouth Scions
What oil and weight are you using?
Old Sep 8, 2010 | 12:04 PM
kc2hje's Avatar
Cleaned the PCV this weekend, will be changing it out along with the coolant in the next few weeks
as to oil it's Pennzoil platinum synthetic 5w-20
I picked up Pennzoil platinum synthetic 5w-30 for the next round if the PCV has no effect as i think 20 weight is = water
Old Sep 8, 2010 | 01:00 PM
elwaylite's Avatar
It's not the oil, 20wt is very durable and fine (my UOA's for 0w-20 are fine). If it's using 2 qts of 20wt over that period, it's an issue.
Old Sep 8, 2010 | 04:42 PM
AAG's Avatar
AAG
DeepSouth Scions
Its def not the oil but using a thicker weight can possibly help with burn off. OP, I'd go with a 40 weight and see if that helps. Many people might think thats too thick but I have over 200,000 miles between two vehicles that have used 10w-40 and they were spec'd for 5w-20 without issues.
Old Sep 16, 2010 | 06:35 PM
DezodDon's Avatar
Normal oil consumption is a calculation based on how you drive. What is normal for most might not be normal for you.
Do you do a lot of higher RPM driving?
The PCV idea sounds good, also check the hose to make sure it isn't clogged with coaked oil. This will cause a greater vacuum which will draw oil into the intake manifold.
awdmofo
Feb 8, 2016 05:58 AM
Col168c
9
Jan 7, 2016 06:55 AM
minter66
Dec 15, 2014 01:45 PM
smilygo
Dec 30, 2003 07:45 PM
BlueBox
22
Nov 7, 2003 08:18 PM
