Issue Starting Car
Old Sep 15, 2010 | 01:32 PM
johnnyb305mia's Avatar
Default Issue Starting Car
So recently my car has been having trouble starting n the battery is ok n alternator is ok so i am seeing if i could get some help it does it on and off n sometimes it takes a couple cranks n then it turns on now here isthe tricky part the car drives fine afrs r perfect accross the board as well
Old Sep 15, 2010 | 03:02 PM
m6ar2cel6oTC's Avatar
Plugs maybe? Or the map on startup?
Sent from my iPhone using Tapatalk
Old Sep 15, 2010 | 03:07 PM
yeah i jus got back home from class ima check the plugs n f/ic wires to make sure they are all in the pins cause u never know what freak thing could happen but i wouldnt think it would be the map on start up mike tuned me back in the begining on june n the car has run fine n started up fine it has been a recent issue over the past 8 days or so but its starting to happen more frequent now i went to start my car to go to class this morning n it took about 3 cranks n then it started i got out of class which the car only sat for about 1 hour 25min n it took me 4 cranks for the car to start
Old Sep 15, 2010 | 04:15 PM
Fuel pump going out?
When I had a 03' gmc Yukon when my fuel pump was going out it took long to crank like your car is doing.
Old Sep 15, 2010 | 04:43 PM
paul_dezod's Avatar
Scionetics
KAD
Was there a decent temp change over the past 8 days from when you where tuned?
i jus checked the plugs n they were ok nothing out of the usual n f/ic wires were fine as well....could the fuel pump going out only cause it to take long to start up or would it affect driveing as well?
Old Sep 15, 2010 | 04:44 PM
nah paul i live in miami n i have been tuned for a while but nah its been hot for the longest 88-92 constantly every day since about mid july
Old Sep 15, 2010 | 06:52 PM
ElevationTC's Avatar
Dear John,
You may want to look into the AEM FIC it self, As we have seen many of those units add additional crank time to starting, mostly due to the way it intercepts cam/crank signals. Some work like oem.. Some take extra cranks!
I would say 4 turns on a AEM FIC is normal. But maybe check with others here, and or friends.
Have a good day
Old Sep 15, 2010 | 07:38 PM
SoFloTC's Avatar
my car takes that long to start.... hold key down, crank ,crank ,crank vrooom
Old Sep 15, 2010 | 09:18 PM
nah chad its not like that i understand that takes a bit longer to start with the f/ic im talking about like for seperate time i have to turn the actual key sorry i shoulda been more specific as well mike
Old Sep 17, 2010 | 01:22 AM
yellow8's Avatar
do u have a check engine lite?
have u monitored fuel pressure while running and after u turn it off?
i should ask are u equipped to check this stuff?
Old Sep 17, 2010 | 01:37 AM
weezyfbayba's Avatar
sell fic buy ultimate car fires right up
Old Sep 17, 2010 | 01:41 AM
lol this!
Old Sep 17, 2010 | 03:20 AM
yes i do but nothing out of the ordinary and the codes have already been discussed with mike n i am not equipped to check the rest
justin i lold at that
but yesterday i decided to play with the f/ic wires n they were all in and stuff nothing out of placed but all i did was play around with them n the last 4 times and it started perfect so now im really puzzled...
Old Sep 17, 2010 | 03:40 AM
yellow8's Avatar
what codes do u get?
Old Sep 17, 2010 | 05:50 AM
P0420 thats for not having the cat
P0411 n P0455 n those are for having a bad gas cap (even thought my gas cap clicks n locks very well n doesnt stay loose)
Old Sep 17, 2010 | 07:59 AM
gingles's Avatar
do you have a return fuel system?
Old Sep 18, 2010 | 03:23 AM
not yet but soon to have an M=TUNED style return system
Old Sep 18, 2010 | 08:59 AM
gingles's Avatar
nvm then. i know with my return system the way i have it ran it takes a while to crank
Jordly221
Feb 13, 2019 05:29 PM
cid_mcdp
Jan 5, 2015 02:45 PM
TheTripleC
Jan 4, 2015 06:46 PM
fluxingnation
Dec 26, 2014 04:28 PM
tC_Normo
Oct 22, 2003 07:20 PM
