E85 Injectors
Old Sep 23, 2010 | 11:02 PM
Rasta's Avatar
Default E85 Injectors
Hey what size do you guys run on your E85 TC (that is built). I am running 1600's they are a biatch to tune then again I plan and making 550whp. Let me know..
Thanks
Old Sep 23, 2010 | 11:23 PM
thendawg's Avatar
Im using 1000cc with return fuel system and twin walbro 255. Im currently running 55 psi static fuel pressure and it keeps up with 18 psi on a 60-1 no prob IDC is around 65-70%. My regulator has rising rate, but im not using it as it seems to make tuning easier with the FIC
Old Sep 23, 2010 | 11:37 PM
trd07tc's Avatar
Whats wrong with the 1600s?
Old Sep 24, 2010 | 12:10 AM
m6ar2cel6oTC's Avatar
if your on a standalone justy takes time but it should idle good. have cams? with 1600 you can reach high 600 so 550whp should be fine on 1600cc.
Old Sep 24, 2010 | 12:26 AM
Rasta's Avatar
Yea it has cams..I know it takes time Im just breaking it in now anyway. We will re-tune after its broken in.
Old Sep 24, 2010 | 02:43 PM
Ace83's Avatar
Ronin Scion
how much base fuel pressure did you set it? bigger injectors might like a slight high pressure at idle.. only have 900cc but it was never a problem
Old Sep 24, 2010 | 04:32 PM
johnhawkins's Avatar
Would 700cc idle at original startup?
Old Sep 24, 2010 | 04:35 PM
Ace83's Avatar
Ronin Scion
^ i dont see why not.. just have to correct the fueling
SloTC1
Aug 16, 2018 02:45 PM
MeDizzy
Oct 8, 2015 03:31 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
brett561tc
Sep 15, 2015 06:33 AM
jdstC1
Jan 13, 2015 04:45 AM
