a lil wheel help....
so i can come on one some work emotions cr-kias that are 17x9 with a offset +44 will the fit finw or will the hit also how big od a spacer would be needed?
^I've been doing some search on that for anyone running those specs and haven't seen anything yet. The concern of the inside of the wheel hitting the suspension(it might clear, IDK) can be taken care of with a spacer as mentioned above. What result are you trying to get out of the setup? Function, flush, etc???
Just get them!! They will look better than your current setup. You want to go stanced? Then do a 10mm spacer in front and 15mm spacer in the rear. What is the issue?
evolving_machine
Oct 21, 2023 01:16 PM
kleecker
Scion xB 2nd-Gen Wheel & Tire
May 22, 2016 06:10 AM
