Scion xB 2nd-Gen Forced Induction Turbo and supercharger applications...
Descendant powered xB2 dyno #'s & pictures
Old Oct 20, 2010 | 01:38 AM
Rob_DESCENDANT's Avatar
Default Descendant powered xB2 dyno #'s & pictures
Hello guys...just wanted to share some great numbers with everyone! Our local customers xB2 just made a whapping 330+WHP!!
This first sheet was the DESCENDANT Turbo Kit @ 8-9psi with TRD exhaust and no other componets:
After a few months go by (look at the dated dyno chart) customer comes back looking for more power but wants his daily driver to remain stealth. So, we add intake manifold & fuel rail and gave it a shot. Below are he’s next dyno numbers...these pulls are his second dyno attempt with the DESCENDANT Turbo Kit at 8-9psi, the TRD exhaust & now the intake manifold & fuel rail. Plus TRD Clutch & LSD.
Basically after tuning the OEM fuel system to the MAX we gained about 20WHP & 30TQ at the same basic 8-9psi boost level.
Engine bay pics:
Also note all dyno numbers above are all thru the OEM air box with TRD drop in filter. :D
Old Oct 20, 2010 | 04:09 AM
huslindan's Avatar
How much can that trans hold before it blows or do we need to wait and see? lol
Old Oct 20, 2010 | 02:32 PM
AAG's Avatar
AAG
DeepSouth Scions
Simply Amazing! I want this kit BAD lol
Old Oct 20, 2010 | 07:14 PM
Tranny is the EZ part! We've made over 700WHP on the STOCK OEM Scion gearbox!
Old Oct 21, 2010 | 12:54 AM
DAILYXB-TYPE-R's Avatar
Rob i have a question for u
i've read on another post about ur v2turbo kit that its adjustable from 5-14psi. is it hard to adjust it myself after installation? ex. DD 7psi Track 12psi
Luv ur kit BTW
Old Oct 22, 2010 | 06:32 AM
Luv ur kit BTW
Its EZ...it is adjustable by removing the 6 allen head bolts from the top of the TiAL MVS wastegate and changing the color of spring inside of it.
The MVS gate is designed to use 10 different spring combinations which allow you to control the boost from 4.8psi to 14.7psi
Old Oct 24, 2010 | 05:49 PM
mikeytomas's Avatar
Hey Rob, it's Mike, the dude with the black/white xB that you guys boosted about 2 weeks ago or so. Great numbers that you all are putting out with your kit! Just wondering, when's the best day to get my tuned to 9 PSI and on the dyno? I'm dying to see the numbers that my ride puts out. Oh, by the way, the kit is performing very well! =)
Old Oct 24, 2010 | 06:53 PM
ScionFred's Avatar
Luv ur kit BTW
What Rob said, although another method is to run a 7psi spring and an external boost controller to raise boost when desired.
Old Oct 25, 2010 | 09:08 PM
thanx rob and scionfred for the info
have another question tho
currently i have the nst un crank, od alt, and pump kit, how would that affect turbo setup?
also whenever i change the psi do i have to adjust the cpu manually or does it self-adjust?
Old Oct 25, 2010 | 10:09 PM
ScionFred's Avatar
IMO the pulleys won't have any negative effect on the turbo setup. I'm running the NST UD crk pulley alone and have had no issues at all. To make life easier on the alt I swapped out most of my oe bulbs for LEDs. I also installed a 170F thermostat and 1 step colder spark plugs.
I'm not sure what psi the Descendant FIC tune is good for but if you tune for max boost, that same tune will be fine for lower boost. If their supplied tune is for 8-9psi, it might need some more tuning to run 12psi. Also, if you want to run 12psi you really need to consider beefing up other oe components like the fuel system, clutch, LSD, motor mounts, etc. and save up for the inevitable engine rebuild and other broken parts. There are very good reasons why all available turbo kits come set to certain boost and power limits.
If you're serious about boosting your XB, I'd recommend starting out with the basic kit, drive it for a while and then see if you still want more power. Big power costs big money.
Old Oct 26, 2010 | 02:34 PM
ScionFred's Avatar
Hey Rob, when you say "TRD exhaust", do you mean that all this guy has is the TRD axle-back on the stock ~2" exhaust system? If so, the results are amazing.
Old Oct 26, 2010 | 05:05 PM
thanx fred for the info so i know what to expect to go f/i, how many miles can people go with f/i 7-9 psi before having any problems with any stock components? driving not to aggressive as a dd
Old Oct 26, 2010 | 06:01 PM
XD40tC's Avatar
Those numbers are great! Hopefully that motor holds up.
Old Oct 29, 2010 | 06:05 PM
ScionFred's Avatar
This thread should answer your question better than I can.
Old Oct 29, 2010 | 07:01 PM
thanx again fred
you save me alot time searching and that's a very good thread gave me more confidence on our motor. didn't know it's that strong stock that can handle that much boost
Old Oct 30, 2010 | 04:27 PM
ScionFred's Avatar
thanx again fred
Happy to help when I can. Personally I wouldn't go more than 10psi on the stock internals but I'm more conservative than some here. My second vehicle is a motorcycle so a blown engine would be a real PITA.
Old Nov 1, 2010 | 07:32 PM
yea i hear ya
use to drive my 07 yamaha r6 as a dd for 4mths it was a PITA until i bought a 07 honda fit as dd and the r6 weekend joy ride
since i dont have my fit no more i'm planing keep boost low like 7-9psi as a dd
Old Nov 8, 2010 | 04:20 PM
Sorry, didnt see this before.
Yes, when I said "TRD exhaust" I ment TRD axle-back on the stock scuba tank!
Old Nov 8, 2010 | 05:14 PM
ScionFred's Avatar
Wow! That's impressive. Thx Rob.
Old Nov 9, 2010 | 03:25 PM
hehehe...honestly, I was surprised myself!
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
my06tc
Jun 25, 2015 12:18 AM
xa007xa
Feb 22, 2015 03:05 PM
PTUNING
Dec 11, 2014 08:09 PM
PTUNING
Dec 6, 2014 03:58 PM
