Aftermarket Subwoofers and OEM Sub
Old Oct 29, 2010 | 04:14 PM
afk247's Avatar
Default Aftermarket Subwoofers and OEM Sub
I have to ten inch explode sub-woofers that I want to put in but I also would like to keep the stock under-cargo sub. Has anyone done the wiring for having a aftermarket sub plus the under-cargo one?
Thanks
Old Oct 29, 2010 | 10:14 PM
iFilipino's Avatar
Thanks
I think reading previous posts have said that the stock subwoofer is pretty small like 6" or something. 10" would def not work in the subwoofer.
Old Oct 29, 2010 | 11:18 PM
b52hDUNN's Avatar
Thanks
Just go after market dude.
Check out these enclosure's I build. You will be much happier with the result.
https://www.scionlife.com/forums/sho...d.php?t=192713
Old Oct 30, 2010 | 04:02 PM
Spicy_McHaggiz's Avatar
A lot of people build enclosures for the tC in the rear. Like ^^^ he said he makes them, and are very good quality. There is also a company that makes an enclosure the exact same shape of the stock sub, but allows you to put any size sub you want into it. Search the forum, I forget who makes them.
No, you cannot use the stock sub for an aftermarket sub.
Old Oct 30, 2010 | 04:25 PM
RoboCop's Avatar
He is asking if you can run both subs at the same time.
Lern to reed gais
Old Nov 4, 2010 | 12:43 AM
Isotopian's Avatar
Yes you can, I had my car set up like this for a good while. Go into the undercargo area, and peel back some of the insulation from the plug that is at the (from the top) bottom left of the stock sub. Once the wiring is exposed, tap into the four wires that are the feeds from FL+/- and FR +/- (I had the pinout for the plug somewhere, if you really can't figure it out, let me know and I'll try to find that for you), wire them into a line out converter ($20 bucks at any walmart or any place like that), run that to your amp's input, and you're done!
Old Nov 10, 2010 | 03:04 AM
allfe777's Avatar
u can run both. just run hi/lo converter. but now stock sub is like 6 in and if u run 10 in sony explod sub most likely it will over power ur stock sub and will not hear it.
NonStopTuning
Jun 29, 2015 07:42 PM
bluemex
Jun 16, 2015 03:22 AM
herwig
Scion tC 1G ICE & Interior
Mar 23, 2015 04:19 AM
TheTripleC
Jan 4, 2015 06:46 PM
rcflyer15
Dec 5, 2014 05:15 PM
