just a tease (WPN-R INTAKE MANIFOLD & RX8 TB) **pics**
Old Nov 7, 2010 | 11:36 PM
jimmyjun's Avatar
Default just a tease (WPN-R INTAKE MANIFOLD & RX8 TB) **pics**
Size:  53.9 KBName:  11062010010.jpg
Old Nov 7, 2010 | 11:40 PM
jimmyjun's Avatar
soon to be mounted on my engine..... also dyno #'s coming soon. enjoy the pics.
Old Nov 8, 2010 | 12:01 AM
emrules2001's Avatar
How do you wire the RX-8 TB? Is it basically PnP? Also, do you have to remove or rotate the engine to get the intake mani in there?
Old Nov 8, 2010 | 02:30 AM
jimmyjun's Avatar
all you have to do for the rx8 tb is to switch the circuit board( wich is the black cover on the top of the tb) with the Tc's to make it work.
ill tell you in a few weeks on how to mount it in the engine, right now the intake manifold is getting some work done to it (new tb flange to mate the rx8TB).
Old Nov 8, 2010 | 03:47 AM
tCs_are_life717's Avatar
interested in the #s. watching
Old Nov 8, 2010 | 07:15 AM
AcidDrop's Avatar
x2
Old Nov 8, 2010 | 04:45 PM
jimmyjun's Avatar
im also very interested in the numbers, im so anxious that sometimes i can even sleep. my car already has a build n/a engine hitting 192whp &173wtq (no cams, no engine management). i will be very happy if i hit 198whp & 180is wtq. we'll see in about 3 weeks
Old Nov 9, 2010 | 12:44 AM
Crippie's Avatar
1UP Crew
watching... good luck with #s
Old Nov 9, 2010 | 04:36 AM
Scotty-tC's Avatar
def watching for updates
Old Nov 9, 2010 | 04:14 PM
jimmyjun's Avatar
thanks!!!!!!!
Old Nov 9, 2010 | 10:52 PM
DMC0585's Avatar
what mods you currently have? to have that setup?
Old Nov 10, 2010 | 08:41 PM
jimmyjun's Avatar
curent mods are:
injen intake
dme header
zpi down pipe
2 1/4 exhaust with magnaflow muffler
unorthodox pulley
act 4puck clutch kit
f1 racing 12.5lbs chromoly flywheel
pnp head
je 11@1 pistons
balanced shafts removed
apex neo
vision grounding kit
vision voltage stabilizer
engine assembly completely balanced
..........and soon to be mounted(3 weeks). weaponR intake manifold and rx8TB.
Old Nov 10, 2010 | 09:11 PM
frankiietc's Avatar
curent mods are:
pnp head
je 11@1 pistons
apex neo
Out of all of those, which one was the one mod that you felt a diffrence on?
and are you reving higher than 6100RPMs?
Old Nov 10, 2010 | 10:37 PM
jimmyjun's Avatar
well, every mod i added to the car i felt a slight gain, like adding an intake then the header and the pulley. but the three mods that turned everything around were (1)PnP head (2) 11@1 pistons (3) apex neo.
*****the car revs to 6,200rpm(oem)
Old Nov 12, 2010 | 02:41 AM
frankiietc's Avatar
Sorry i stand corrected.
Anyways, How much was the PnP head and the Apex neo?
easy install?..
Old Nov 12, 2010 | 03:03 AM
jimmyjun's Avatar
easy install?..
a very good PnP head will range from $500-up to thousands of dollars, it all depends what you want. me personally, i didnt spend more than 50 for the abrasives and that was it, me and my friend did everything.
installing the head is a pain in the butt, only because toyota decided have so little space in the timing cover side and to a bolt in the timing chain thats like 5 inches long and you have to jack up the engine in order to get it out, other than that it's not that bad. with pacience and a lil' elbow grease it can be achieved.
the apex neo its very easy to install (at least on 05-06 engines/ 5 plug ecu) all you have to do is wire the cables with the specific diagram wich is T-11c for 05-06 engines.
Old Nov 15, 2010 | 07:01 PM
jar2709's Avatar
how much was the intake?
Old Nov 16, 2010 | 02:46 AM
jimmyjun's Avatar
intake manifold was $500 with shipping included
Old Nov 19, 2010 | 04:38 AM
KillaKeola's Avatar
what is the diameter on the rx8 throttle body? Good luck on the build. Im glad to see someone taking the risk and being the guinea pig.
Old Nov 19, 2010 | 07:35 PM
jimmyjun's Avatar
the rx8 TB is 70mm, oem is about 58mm. thanks bro, someone has to do it.
