Rear emblem plate......
Old Nov 26, 2010 | 11:13 PM
memback's Avatar
Default Rear emblem plate......
Rear plate (plastic) on my trunk fell off when I lifted it. How many of you had this happen to you. Is it something I should bring up to toyota?
Old Nov 26, 2010 | 11:32 PM
Jon's Avatar
Jon
Moderator
Moderator
They'll probably tell you it's your fault for improperly opening the hatch. You don't lift from the handle, you press and hold the button then lift from the bottom.
Old Nov 26, 2010 | 11:36 PM
DJ08tC's Avatar
yes it has happened to plenty of people and there are plenty of threads on it. and no the dealer wont do anything about it more than likely.
Old Nov 27, 2010 | 02:54 PM
memback's Avatar
oh well
Old Nov 27, 2010 | 02:58 PM
highvoltage1's Avatar
If its under warranty you should try! I have a CF one and pull there and no problems. I never had any problems when i had my stock one either!
Old Nov 27, 2010 | 03:01 PM
Also we call it a "hatch garnish" in case anyone doesn't know what your talking about or future posts about this!
Old Dec 1, 2010 | 02:32 AM
blackdarthtc's Avatar
hey high voltage i also have a cf garnish but when i bolted it, the tightening created dimples on the outside, did u had that problem and is there anything that i can do?
Old Dec 1, 2010 | 04:58 AM
Spicy_McHaggiz's Avatar
I thought the garnish was held on by plastic clips, not bolts of any sort....
Old Dec 1, 2010 | 08:12 PM
nope it has two bolts that are fiberglassed in and then you put the nuts from the other side, the reason why it dimples, i think, its because the bolts are fiberglassed in. I didnt even tighten it too hard.
Old Dec 2, 2010 | 03:46 AM
Aurora's Avatar
Can you post up some pix of how bad it is? If you end up getting it replaced, what will you do with this one? IDK if you've seen my v2.0 illuminated garnish but I'm looking to make another, try out some new ideas.
killahXB2
Mar 29, 2016 04:22 AM
jaspercanda
Mar 6, 2015 09:48 PM
nacy333
44
Oct 4, 2009 11:18 PM
Jugglah
Jan 8, 2004 04:05 AM
1sikxb
Oct 29, 2003 05:10 PM
