Need help fast!!!!!!!!!!!
Old Dec 15, 2010 | 11:18 PM
oreoremix42's Avatar
Exclamation Need help fast!!!!!!!!!!!
Ok so last week or so I was driving doing about 100mph in 4th gear at 5500rpm. While I was driving the car sputter and the check engine light came on and then the car seemed fine. Was about 5 days and it was completely fine. Now the car as I was almost home sputtered check engine light vsc and traction control lights all came on. VSC is blinking. I was coming up the driveway in 3rd gear and the car was sputtering like crazy. I came to a stop and the car was rocking bad from teh sputter. No power at all. And this time i was at 45mph at 3500-4500 rpm
Old Dec 16, 2010 | 01:25 AM
DJ_FroZone's Avatar
check your intake. make sure its all connected. and the MAF sensor is still in place. that happened to me once. it uncoupled itself and the engine just started dying.
Old Dec 16, 2010 | 01:27 AM
Ok one thing I want to say is that I went out little bit ago and the power seemed ok. I will check the maf tho to.
Boosted Scion's Avatar
I agree check your MAF sensor. If its not that, have it checked out. You may have blown something. Although always start with the small things then check the big things.
Old Dec 16, 2010 | 01:36 AM
Let us know what is when you find out. I am curious to what it could be
Old Dec 16, 2010 | 01:51 AM
This ____ has me nervous
Old Dec 16, 2010 | 02:12 AM
TrevorS's Avatar
Damn dude ! I don't travel anywhere near that speed, but I don't see why it would be a problem . It could be anything from a wiring problem, sensor problem, to maybe even a filter ! I wish you luck and am interested in the diagnosis.
Old Dec 16, 2010 | 03:12 AM
^^bump
Old Dec 16, 2010 | 03:45 AM
It has been months since I have driven at 100mph and I wanted to have fun one night then that happened and said nope never again lol
Old Dec 16, 2010 | 04:49 PM
Pasquale's Avatar
If it was the MAF the RPM's would pulsate. If its not doing that then I would assume thats not the problem. I wish I could hear it becuase it sounds like you're not firing on all pistons. Which isn't good.
Take your car to a Toyota dealership and have it scanned. Its going to cost you about 90$ but you'll know exactly whats wrong with it.
Old Dec 16, 2010 | 06:03 PM
Well now the car seems okay. And the check engine light has gone off now?
Old Dec 16, 2010 | 10:32 PM
AAG's Avatar
AAG
DeepSouth Scions
You have a 08? Did your vin # fall under the TSB for the engine wire harness?
Old Dec 17, 2010 | 01:11 AM
papo's Avatar
theres a tsb for the engine wireharness?
Old Dec 17, 2010 | 01:40 AM
How do I check for a recall?
Old Dec 17, 2010 | 02:45 AM
TrevorS's Avatar
I'm pretty sure there was never a recall for this; however, the TSB is in the package of xB2 technical files I posted earlier. I think you downloaded them already, so take a look.
Old Dec 17, 2010 | 06:13 AM
CIONIDE's Avatar
Here's the thread with the wiring harness TSB info & discussion. The actual VIN cutoffs for auto & manual trans are on page 2, post 27.
https://www.scionlife.com/forums/sho...d.php?t=180494
Old Dec 17, 2010 | 08:35 PM
Pulled my plugs last night. They were wet. Going to start with the simple and replace my plugs and see what happens.
Old Dec 18, 2010 | 01:08 AM
Ya your plug is fouled. Was there any oil on the plug?
Old Dec 18, 2010 | 01:45 AM
Stuartz's Avatar
Check your cylinder coils. Ive had two go on my 08 Xb
Old Dec 18, 2010 | 02:44 AM
Was very little oil. smelled it more then anything. Just replaced them a hour ago. will test them out tomorrow and see what happens. I can replicate the issue. so shouldn't be a problem figuring out if it was the plugs or not.
