Magnetic drain plug?
Old Mar 9, 2005 | 06:06 PM
yamaha16bw's Avatar
Default Magnetic drain plug?
I did a search to try and find some info on this with no luck. I was wondering if a Magnetic drain bolt would do any good? i have raced Motocross for a few years and ive always used Magnetic drain plugs. You wouldnt belive some of the crap that thing can trap! I was just thinking would it have the same effect on a car which has an oil filter? Or perhaps trap stuff you would want the filter to get?
Thanks for any help!!!
Old Mar 9, 2005 | 06:19 PM
reagulator's Avatar
the reason that you use magnetic drain plugs on a motorcycle is to catch metal filings from the transmission. In a motorcycle you use the same oil for BOTH the engine and transmission. On a car it has two different oil pans for the engine and transmission. The transmission pan actually has a couple of magnets already in there for this reason
Old Mar 9, 2005 | 06:21 PM
yamaha16bw's Avatar
so your saying its pointless?
Old Mar 9, 2005 | 06:25 PM
reagulator's Avatar
yes
regular oil changes are enough after break in period
Old Mar 9, 2005 | 06:35 PM
dgHotLava's Avatar
moved...
WarrenSteve's Avatar
past carws that i have had, and replacement plugs i have bought, come with a little magnet built into the drain plug. Never seen any metal on it though.
Old Mar 9, 2005 | 06:45 PM
yamaha16bw's Avatar
Thanks for the advise!!
Old Mar 10, 2005 | 02:19 AM
B2FiNiTY's Avatar
There is no harm in putting a magnetic drain plug in the oil as well as transmission.
I have magnetic drain plugs in on my oil pan and tranny. This is not on a scion though.
As far as catching materials, the oil always stays pretty clean minus some smudge but the transmission usually picks up some metal spikes.
Old Mar 10, 2005 | 04:57 AM
reagulator's Avatar
most transmission pans already have magnets in them
Old Mar 10, 2005 | 05:17 AM
B2FiNiTY's Avatar
Yes they do but an added magnetic drain plug still will catch shavings.
Old Mar 10, 2005 | 10:58 AM
hotbox05's Avatar
And give you an approximation of how much shavings are present , visually that is , rather than breaking down the transmission to check the internal magnets.
Old Mar 10, 2005 | 10:59 AM
hotbox05's Avatar
As for motor oil magnetic plugs , why the heck not , allthough metal chips , flecs are less prone to happen any metallics that you can stop from circulating is a great thing.
Old Mar 11, 2005 | 04:10 PM
LuminicsBulbs's Avatar
I feel that you would benefit from getting one especially for the cheap price. I believe they run about $25-$30 I think its a good investment. Its not bad if you dont get one but at the same time it could help if you do get one. There are some on the pan but then they collect there if you can get them all to the plug then when the plug is pulled you could just whipe it off and no shavings in the pan anymore.
Old Apr 8, 2009 | 03:55 AM
OakToddler's Avatar
On the xb, are the oil drain plug and tranny plug the same size?
Wrencher
Mar 12, 2023 04:54 AM
RokGoblin
Scion tC 1G ICE & Interior
Aug 11, 2015 05:24 PM
Wrencher
Jul 29, 2015 01:38 PM
semlin
Jul 29, 2015 02:07 AM
Bish80
Jul 24, 2015 02:02 AM
