Question about the Grill/Bumper
Old Jan 22, 2011 | 10:40 PM
MJA_Scion_tC's Avatar
Exclamation Question about the Grill/Bumper
Ok so something must have happened when I went over a bump because my Grill wont stay in place. I looked under the hood an popped it back into place but everyday it pops out. Im really **** (no homo) about perfection so when I see it out of place it drives me nuts. It looks like 1 of the clips that holds the grill in place is broken therefore the grill is slipping out. When I took it to the dealer (to get work on a few other things that were wrong - had to get a new gas cap & tire pressure sensor) they said its the clip which I knew, but that they would need to replace the WHOLE bumper...What should I DO !?
I want to get a lip kit for my scion & eventually get it re-painted (Super White or a semi-dark Red) & I want to egt a new grill without the scion logo. Should I get the new bumper or use some kind of tape/glue ?
PLEASE HELP !!!
Old Jan 22, 2011 | 10:58 PM
ack154's Avatar
Those clips are molded pieces of the bumper itself... So yes, if you want to replace the clip, you have to replace the bumper cover. If I were you, I'd look into rigging some sort of other option.
Old Jan 23, 2011 | 05:25 PM
bump
need more info on this.
Old Jan 23, 2011 | 09:11 PM
RevivedPhoenix's Avatar
If I understand you correctly you're looking to replace your OEM grille with a new one anyway, right?
The grille that I have, from GrilleCraft.com, doesn't use the stock mounts. This would both get you that new badgeless grille you were looking for and solve your clip problem.
Both GrilleCraft styles here. http://www.grillcraft.com/applicatio..._Scion_TC.aspx
Also, check out how it looks on my Flint Mica 2010.
Old Jan 23, 2011 | 09:15 PM
Exactly what I'm looking for ! Just a question though how do you install the bumper is it easy or should I take it to a mechanic type friend?
Old Feb 1, 2011 | 10:04 PM
Bump on this.
Still need some more info please.
Old Feb 1, 2011 | 10:35 PM
x_Batman_x's Avatar
I think you can just use zipties.... so if you're good with a drill and zipties you should be fine lol
Old Feb 1, 2011 | 11:00 PM
Hayseed's Avatar
Zipties are your friend. Seriously it wont take that long to rig something up. A lot cheaper than those grills posted
Old Feb 1, 2011 | 11:03 PM
Zip ties might work.
@Hayseed - I DO want a new grille..So i'd still be buying a grille regardless but I wont get one untill I can figure out the bumper.
Old Feb 5, 2011 | 12:38 AM
Sorry for not posting earlier. I got sent away on a business trip.
The GrilleCraft grilles come with the instructions and hardware needed to mount them. Take off your front bumper, just clipped in with two different types of plastic clips, and drill some small holes to insert the bracing rods attached to the grilles. No mechanic needed, just takes a little time and maybe an extra hand to hold your cumbersome bumper down while you drill the holes.
If you're too leery about drilling into your own bumper then take it to a mechanic, I guess. Really easy and doesn't take any special knowledge to finish the project.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
jairolla_89
Apr 2, 2015 09:41 PM
Scionxa180
Mar 13, 2015 04:39 AM
xBassist
9
Jan 21, 2004 07:34 PM
