Install SafcII on 07 tC..Help..
Old Mar 6, 2011 | 05:09 AM
Betz's Avatar
Default Install SafcII on 07 tC..Help..
I know that people say that it is pointless to put the SafcII on the tC but I've had luck with it on my other cars so I figured I'd give it a try but I cant find a diagram
for the tC's ECU to match up. I've searched the forums for one but I guess I'm not looking in the right places. So if you guys could help me I'd greatly appreciate it!
___
Old Mar 6, 2011 | 04:59 PM
tC_Crisis's Avatar
https://www.scionlife.com/forums/scion-tc-1g-ice-interior-1647/scion-tc-electrical-wiring-manuals-05-07-a-73323/
hope this helps
Old Mar 7, 2011 | 01:29 AM
Betz's Avatar
thanks man but ive searched those already!
Old Mar 7, 2011 | 06:12 PM
thendawg's Avatar
All you need is the ECU Pinout - it's on Dezod's website under Technotes. IIRC I believe the SAFC interrupts the MAF signal and taps into the tach wire.
Than of course you need power and ground, but this really shouldn't be too bad of an install (Well I am comparing to the fact that I hard wired my Ultimate, which is about 50-60 wires to connect lol)
___
Old Mar 8, 2011 | 03:31 PM
Betz's Avatar
That is exactly what I needed! Thank you!
Old Mar 8, 2011 | 03:36 PM
jimmyjun's Avatar
Here is the ECU Pinout for 07-10 Scion tC
E8-3 / Ground
E8-20 / Throttle
E7-28 / Airflow
E5-1 / RPM
E4-1 / Power
__________________
Old Mar 8, 2011 | 03:58 PM
jimmyjun's Avatar
red wire- power
green wire-rpm
gray wire- throttle signal
brown wire-ground
black wire- ground
yellow wire- airflow signal output
white wire- airflow signal input
*** airflow wire has to be cut in two****
*** ground wires have to be install 3 inches apart from each other********
Old Mar 8, 2011 | 04:01 PM
jimmyjun's Avatar
I forgot to mention that the tC runs on HOTWIRE, sensor 24-24
__________________
Old Mar 9, 2011 | 01:22 PM
Betz's Avatar
Got it! Thanks Jimmy!
Old Mar 23, 2011 | 07:07 PM
WGDPR's Avatar
jimmy (soy de PR)
is this pinout the same for a 2010 XRS??
Old Mar 24, 2011 | 06:30 PM
jimmyjun's Avatar
saludos!!!!!!
nope its not the same ecu pinout.... your ecu has two plugs, one super big and one small.
jonesspeed
Jan 26, 2013 06:45 PM
WendysOrBust
Apr 24, 2008 08:48 PM
Aznxguy4life
Jul 20, 2007 04:32 AM
ef91hatch
Scion tC 1G ICE & Interior
Apr 1, 2007 04:28 AM
jOaNgHoSt
Jul 10, 2006 12:57 AM
