HELP..ANY ideas??
Old Mar 9, 2011 | 04:17 AM
pena1128's Avatar
Default HELP..ANY ideas??
So my car started leaking oil after i had just gotten an oil change so i thought it might have been either i didnt tighten the screw or oil filter.
so when i checked they were both DRY..i realized there was oil near my fender liner all the way up to the top.
I checked my cv boots and they seemed fine can it be its the shock/strut that is messed up?
and IF it were the cv boot would it be possible to get the oil so far up?
Old Mar 9, 2011 | 05:29 AM
MrBurrito's Avatar
it could be that there was just spilled oil on or aroundthose ares if you dont see any leaks put some cleanm cardboard under your car and follow the spot up into you engine bay
Old Mar 9, 2011 | 03:40 PM
Gripking's Avatar
also check your brake lines/caliper maybe something is loose or torn?
Old Mar 9, 2011 | 06:25 PM
Spicy_McHaggiz's Avatar
Are you sure its OIL or not something else? Struts don't have motor oil in them, so it won't be the same consistence or color. CV boots use a grease. Is this fluid located inside the fender liner? Have you check your fluid levels?
Old Mar 9, 2011 | 06:41 PM
pena1128's Avatar
what was on the ground was clear..but when i lifted the car it was like grease but it even had it on the bumpstop at the very top
Old Mar 9, 2011 | 10:43 PM
Pictures would help out a lot. Clear liquid under the car wouldn't concern me, especially if its the consistency of water. You can visually check CV boots under the car.
akarnofel
Scion xB 2nd-Gen Wheel & Tire
Aug 26, 2015 07:49 PM
jbernard
Aug 22, 2015 09:14 PM
StxArOne
Scion xA Aero & Exterior
Aug 21, 2015 06:44 PM
Brently1
Aug 12, 2015 10:54 PM
TOOSLOW
Jul 25, 2015 05:19 PM
