HELP..ANY ideas??
So my car started leaking oil after i had just gotten an oil change so i thought it might have been either i didnt tighten the screw or oil filter.
so when i checked they were both DRY..i realized there was oil near my fender liner all the way up to the top.
I checked my cv boots and they seemed fine can it be its the shock/strut that is messed up?
and IF it were the cv boot would it be possible to get the oil so far up?
Are you sure its OIL or not something else? Struts don't have motor oil in them, so it won't be the same consistence or color. CV boots use a grease. Is this fluid located inside the fender liner? Have you check your fluid levels?
