Progress sway bar issue
Old Mar 10, 2011 | 04:30 AM
Coolwaterz's Avatar
Default Progress sway bar issue
i first set it on race setting. the stiffest i can be. and i went to middle cuz it was killing my rear tires. now i noticed the sway bar hitting against something when i turn or go up the drive way.
anyone with a same issue?
Old Mar 10, 2011 | 05:05 AM
Spicy_McHaggiz's Avatar
Sway bar has almost nothing to do with how your tires wear fyi.
Old Mar 10, 2011 | 06:12 AM
shadowler's Avatar
explain how it was killing your tires? most likely you are just taking sharp turns all the time ?
Old Mar 10, 2011 | 07:25 AM
Coolwaterz's Avatar
it makes me wanna take turns as fast as i can?
anyways is this normal with all sway bar? it hitting ur car on turns? when its set at soft?
Old Mar 10, 2011 | 06:39 PM
RoboCop's Avatar
You need aftermarket endlinks. If you have them, you need to adjust them so the bars run parallel to the ground when the car has full load on the suspension.
Old Mar 10, 2011 | 07:53 PM
pinoyFMtC's Avatar
Yeah, I had a similar issue when I had the progress swaybar. The issue was the adjustment on the endlinks. Since it's a Progress sway, I'm assuming you're using the adjustable ones that come with the sway? To stiffen the sway, the endlinks must be shortened, and to soften the sway, the endlinks must be lengthened (due to the alignment of the holes). Once the endlinks were adjusted correctly (and even), the sway stopped hitting on the lower suspension on my car.
And RoboCop is right, you wanna adjust the endlinks with full load on the suspension, so its parallel to the ground.
And PS: You're in Milpitas? I love that area
Old Mar 11, 2011 | 01:17 AM
mystik's Avatar
CinSity Scions
be sure to use the washers included with the progress endlinks...there are instructions on how many washers to use on each side of the swaybar...
http://www.progressauto.com/ecom/download/62.2180.pdf
Old Mar 11, 2011 | 09:53 PM
xdejablu3x's Avatar
My TRD sway bar was rubbing against something because the bushing clamp was undone. I guess there was a bolt that was tightened down. Always look for the simplest solutions.
Old Mar 11, 2011 | 10:08 PM
Coolwaterz's Avatar
thanks guys i forgot about shortening the spacers.
CombatmedicR56
Nov 12, 2020 01:53 AM
Monkey343
Scion xD Suspension & Handling
Nov 10, 2016 02:07 PM
JPuehl
Jan 10, 2015 01:01 AM
TheTripleC
Jan 4, 2015 06:46 PM
yamahamx117
Dec 25, 2014 01:54 PM
