how did you run your backup cam wire?
Old Mar 22, 2011 | 06:47 AM
Poe408's Avatar
Default how did you run your backup cam wire?
for those who've done it... how did you run the wire for the backup cam through the trunk door? did you drill? if so, where?
Old Jun 11, 2011 | 12:25 PM
hotrod555's Avatar
Default rear cam install
i cant believe no posts, i plan on doing it this weekend after i figure what cams are available, i'll let ya know,
Old Jun 24, 2011 | 03:58 AM
pyroman131's Avatar
I don't have a backup camera or a system in my car, but I would assume that if you were hooking it up under the hatch garnish (above the license plate), you would want to run the wires through that hatch garnish itself. I would drill a small hole through the garnish just large enough to fit the backup wire through it. It would be cleaner and more simple.
There are some xB's out there that have them installed by removing the rear wiper and fitting a camera into the plug spot. I forget who has them on ScionLife, but I've seen at least two xB's like this. I think Pasquale has this mod.
Old Jun 24, 2011 | 10:34 PM
xtylerx's Avatar
I ran mine up from the wiper hole, then tucked in the hatch frame around the rear window, through the rubber boot that contains the brake light, wiper, etc. harness, then underneath the headliner, down the b-pillar, along the lower frame of the front passenger door, behind the glovebox, then into the back of the head unit. Kind of a pain in the rectum, but worth it in the end. Hope that made sense.
Old Jun 24, 2011 | 11:04 PM
XBinRochester's Avatar
I did this to mine, so since I didn't have to drill a hole in the door, I haven't replied to this question.
Old Jun 25, 2011 | 12:55 AM
isomswim's Avatar
im going to try and run mine this weekend if i have time between the dynamat and putting it all back together. going to try and run everything along the top. mounting the camer just underneath the brake light on the inside to give me a higher viewpoint gotta check it all out first. anyways hope this helps some and gives you a few good ideas.
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
clickclickw00t
Feb 18, 2015 08:57 PM
XB06
Feb 16, 2015 06:03 PM
mav261
10
Feb 11, 2015 02:45 PM
Green_rino
Scion FR-S ICE & Interior
Jan 20, 2015 01:41 AM
