Interior Lighting Issues
Old Mar 24, 2011 | 11:30 PM
SporkLover's Avatar
Default Interior Lighting Issues
Ok, I am posting because in my searching I haven't found someone with the same issues.
Car: Completely Stock 2005 Scion tC. Stock Head unit, stock everything.
Issue: When Headlights are turned on, Radio/HVAC AND Dash Lights will not turn on.
Troubleshooting so far:
The dimmer switch is turned on, not off
Does not appear to have any loose wires in the cabin or under hood.
The fuses are all fine.
I have come across multiple threads pointing to the common 2007 HVAC issues, but the additional Dash Light issues do not seem to fit that issue very well. So I wanted to just shoot this question to the forum, and see if there are any other known issues that I should start with before I take apart the dash and try the HVAC fix.
Old Mar 25, 2011 | 05:22 AM
TrueHyperFoX's Avatar
Might as well just try it bro. Mine did the same thing but i have an 07 so the HVAC solder fix worked for me. No harm in making sure they are on right! It literally took me less than 30 minutes to disassemble, solder, test then reassemble.
Old Mar 25, 2011 | 03:29 PM
SporkLover's Avatar
That's the plan if no one else has any ideas. I may try and replace the dimmer switch first
clickclickw00t
Feb 18, 2015 08:57 PM
757_BRDFLY
Jan 9, 2015 12:29 PM
VCUBoy714
Scion tC 1G ICE & Interior
Jan 5, 2015 08:46 PM
tC6M
Nov 26, 2014 06:44 PM
sithscripter
9
Sep 26, 2003 05:27 AM
