Anyone install the Center Console from 2011 into earlier year xB?
Old Apr 29, 2011 | 07:00 PM
moontom's Avatar
Default Anyone install the Center Console from 2011 into earlier year xB?
I just checked the 2011 xB and the big change was the center console.
I want to put it in my 2009....is it possible to do this? looks like we'd sacrifice the folddown armrest but b/c the rest of the interior specs are the same, it should work.
anyone try it?
thanks in advance for any insights!
TM
Old Apr 29, 2011 | 07:30 PM
Pasquale's Avatar
Sure, just be willing to pay Hundreds of dollars for it.
Old Apr 29, 2011 | 08:58 PM
Ruztiko's Avatar
Originally Posted by moontom
looks like we'd sacrifice the folddown armrest...
TM
But you gained a center compartment lid that slides out for you
Old Apr 29, 2011 | 11:06 PM
CIONIDE's Avatar
MSRP = $215.46
TRDsparks = $165.90
Old Apr 30, 2011 | 05:30 AM
pyroman131's Avatar
Originally Posted by CIONIDE
MSRP = $215.46
TRDsparks = $165.90
Do you have a link for it? I can't find it in TRDsparks.
Old Apr 30, 2011 | 05:48 AM
CIONIDE's Avatar
I don't know how to get a direct link to work, but if you go to their home page, click on the search button in the square that says "Replacement OEM Parts Search", then enter the year, make, and model (2011, Scion, xB), then type in "center console" where it says "Part Number or Keyword", and click on the search button it will pop up.
Old Apr 30, 2011 | 07:53 AM
cTek's Avatar
I hope someone ends up trying this swap.. The existing compartment is so tiny!
Old Apr 30, 2011 | 08:55 PM
Dark Gecko's Avatar
$165.90 is not bad at all... When I get some extra cash Im definitely doing this!
Old May 1, 2011 | 01:43 AM
Darrenohooligan's Avatar
One of my buddies was with me at the stealership, and we started tinkering with my center console, and we're pretty sure it can be swapped over with some work. The layout is pretty similar. It doesn't look all that tough. Once my coils are installed and the windows tinted, I'm thinking we're going to try it...
Old May 1, 2011 | 05:15 AM
pyroman131's Avatar
Originally Posted by Image Courtesy of TRDsparks
Is it just me, or does this 2011 center console look exactly like the 2008-10 center consoles? I can't tell if it's higher or not. Granted, I know that the 2011 console is different, but I can't seem to differentiate between the two.
Old May 1, 2011 | 05:59 AM
CIONIDE's Avatar
Looks like the same schematic for the 2008-10 xB center console, even though they're different.
Old May 1, 2011 | 06:31 AM
SamCarroll's Avatar
i hate that my 08 console sits so low. Im 6'8" i have a super lean going on when im driving. That driver side arm rest is a joke. Im down to look at the 11' at work and see what i can do about getting a taller one in my 08.
Old May 5, 2011 | 01:12 PM
moontom's Avatar
so I checked w/ Scion "tech support" -- they say it's possible to swap but there are potential issues....incl the placement/function of the AUX jack.
in the next breath they added that this modification would void the warranty for any of the affected parts/systems/etc.
if the dealership thinks it's possible to move the aux jack and make it functional I'm gonna consider doing this....
Old May 5, 2011 | 02:22 PM
Century's Avatar
BUZZKILLLLL
Old May 6, 2011 | 07:39 PM
Sparks_Scion_TRD_Parts's Avatar
It is quite expensive for the whole console, as you may need the whole entire thing. Apparently the 2011 sits a little higher than the 2010. What exact part are you looking for and I can get you the part number on it?
Old May 7, 2011 | 01:33 AM
oreoremix42's Avatar
TRD SPARKS, do you think if we got just the lid it would fit? Would it attach to the latch and click close?
Old May 9, 2011 | 05:09 PM
moontom's Avatar
basically it is the entire center console and any mounting hardware. the sense I got from the dealer service dept was that we could keep the cupholder component but everything beyond that would need to be replaced.
oddly the schematics for the '08 and the 11 console look identical, even tho the actual equipment is somewhat different....
you asked about the Part #: can anyone help me determine everything I might need to do this swap? it's impossible to tell from the toyota site. and I can't seem to find part numbers when I do the search on the Sparks site!
thanks
TM
Old May 14, 2011 | 10:51 PM
SamCarroll's Avatar
Its the same exact part #s for the 08 and 11' console top and pieces. Im not sure if theres an error in toyotas microfish but thats what it tells me.
Pt# 585905-12700-B0
Source: Im a parts associate at a local Toyota/Scion dealer
Old May 14, 2011 | 11:01 PM
TrevorS's Avatar
Pt# 585905-12700-B0
Well, if they are the exact same part numbers, then if you order them, you'll get the exact same parts. Sounds like the fiche didn't keep up with the model refresh.
Old May 14, 2011 | 11:03 PM
SamCarroll's Avatar
whats weird is that everything else such as bumpers and lighting updated. But its the same exact console picture/information.
