Help With Heater!
Old Apr 30, 2011 | 02:47 PM
R3define's Avatar
Default Help With Heater!
So after I bought my car I noticed that either way I turned the temperature ****, it usually stayed cold. So I know for a fact after looking up under the passenger side that the fan acuator door is moving. But when you change the temperature the acuator doesn't ever move the right amount or direction. So I know the motor works but it doesn't work correctly. Is there a way to reset this or is the motor shot? New HVAC? Any help would be awesome. Thanks.
Old Apr 30, 2011 | 04:25 PM
Irishguy0224's Avatar
Did you buy it from a dealer?
Old May 2, 2011 | 03:20 AM
R3define's Avatar
No. Unfortunately.
Old May 2, 2011 | 07:01 PM
sciontc_mich's Avatar
if you've confirmed that the blend door motor is working, but not completely, chances are that the hvac board is bad. that's all the buttons and **** connect to in the dash. might want to start looking for a board from a junkyard, since it's almost $500-600 new from the dealer.
the board has had issues before and can cause a lot of issue, but once replaced it seems to never come back to failing again.
Old May 2, 2011 | 10:09 PM
R3define's Avatar
So the HVAC is probably bad then is what your saying? Like I can just find a junkyard whole unit and buy that?
Old May 3, 2011 | 01:19 AM
as long as you can see that the blend motor is working and isn't binding, then yeah most likely the main board "brains" of the hvac (which is what you see in the dash) is bad. junkyard but only if they tell you that the part is working. i think someone here, oh yeah engifineer knew of where they were to buy one. you could contact him, he has experience with them. here's his account :
https://www.scionlife.com/forums/members/engifineer-135231/
Old May 3, 2011 | 02:18 PM
R3define's Avatar
Thanks for your help. Its much appreciated.
hydrogen
Jul 14, 2020 09:41 PM
MrMeanor
Sep 28, 2019 04:37 PM
Daddyfredregill
Aug 18, 2015 01:31 PM
rrtxdrvr
Jan 24, 2015 03:08 AM
ERIC-TC
Aug 20, 2006 02:38 AM
