Keyless Entry Not Working
Old May 16, 2011 | 03:43 AM
bbtpd's Avatar
Default Keyless Entry Not Working
I was working on my car's electronics and long story short I had a crossed wire without knowing so when I turned the power back on I blew a few fuses. I went through the all of the fuses and replaced the ones that needed to be replaced.
The problem is that the keyless entry still doesn't work, and the auto headlight shut off when you turn the car off and open the door doesn't work either.
I checked the wire diagram to see if I missed a fuse and came up with nothing. I also tried to reprogram my key just for the chance that the key could be the problem, and it wouldn't even let me reprogram it.
So, if anyone has any ideas or fixes that would be greatly appreciated.
Old May 17, 2011 | 08:04 AM
stussy1's Avatar
need more detail in your explanation:
what wires did you cross, what were you working on when they crossed, what fuses blew etc
Did you check both fuse boxes? (under the hood, under the steering column)
Old May 28, 2011 | 07:16 AM
peyton331's Avatar
X2, could be a relay or security brain?
Old May 28, 2011 | 03:03 PM
bbtpd's Avatar
I crossed the + and - going to the cigarette lighter. So far under the dash I had to replace the cigarette fuse and the gauge fuse. And I have checked both boxes.
What I was working on was my car came with the under dash lighting. The lights had start to flicker over bumps so I was soldering them directly into the cigarette wires instead of how they came just clipped in. I wasn't paying attention or someting and touched the wires together and then everything went pop.
Also another problem has developed (or I didn't notice at first) where my hvac doesn't turn off.
VCUBoy714
Scion tC 1G ICE & Interior
Jan 5, 2015 08:46 PM
randomsuper
Dec 15, 2014 08:29 AM
ShadowMage
16
Jul 25, 2004 06:02 PM
hnefrdo
Dec 24, 2003 04:18 AM
