rear hub replacement
Old May 21, 2011 | 03:05 AM
aaros's Avatar
Default rear hub replacement
I know, FNG and his first post is about the rear hubs
I had the passenger side changed about a month ago, thought that the price of the hubs was bad enough not to mention the 150 they wanted for labor so i changed the drivers side with the help of my Father in law.
everything was going well till I pulled the last bolt from the hub only to find that bolt was cross threaded. found a 12x1.25 thread chaser and a new bolt and finished the job in what would have been about 2 hr.
Heres my questions, the FIL was adamant about not using the impact to snug the three 14 and the new 19 bolts on the hub assembly, I got them as tight as i could with a 14 inch 1/2 ratchet but am a little worried about them working loose.
Next question is the stupid VSC light is still flashing, is there a reset or do i need to go around and check the connections? I know the one we did tonight was good but not sure about the other three.
Thanks for any help guys!
Old May 14, 2012 | 02:36 AM
LimoBox's Avatar
How did you remove your rear hub? I can't get mines to budge one bit after the bolt removals.
Old May 17, 2012 | 01:52 AM
aaros's Avatar
rubber mallet and some judicial hits. Make sure that you unplug the speed sensor first!
Old May 17, 2012 | 02:41 AM
TrevorS's Avatar
The only problem I'm aware of relative to the rear hubs is associated with winter snow and salt causing misbehavior of the ABS speed sensor connectors. The solution for that appears to be to clean the connectors and protect them from corrosion.
Is your problem something different?
tato63
Scion tC 2G Wheel & Tire
9
Sep 30, 2015 09:55 PM
torranosaurus
Jan 28, 2015 04:53 AM
Miqmiqmiq
Jan 15, 2015 03:30 AM
tapetheducks
Scion xB 2nd-Gen Wheel & Tire
Jan 14, 2015 06:25 PM
TheTripleC
Jan 4, 2015 06:46 PM
